428 Engines
By Mark MacPherson
Ford combined attributes that had worked well in previous incarnations of the FE: a 3.98 in stroke and a 4.13 in bore, creating an easier-to-make engine with nearly the same displacement. The 428 engine used a cast nodular iron crankshaft and was externally balanced.
Standard 428 in³ FE engines were fitted to Galaxies (badged simply as ‘7 Litre’) and Thunderbirds in the 1966 and 1967 model years.
Applications:
- 4V, 10.5:1
- 345 hp (257 kW) at 4600 rpm and 462 ft·lbf (626 N·m) at 2800 rpm
- 1966-1967 Ford
- 1966-1967 Ford Thunderbird
- 1966-1967 Mercury
- 1967 S-55
- 360 hp (269 kW) at 5400 rpm and 459 ft·lbf (622 N·m) at 3200 rpm
- 1966-1968 Ford Police Interceptor
- 1966-1968 Mercury Police Interceptor
- 340 hp (254 kW) at 4600 rpm and 462 ft·lbf (626 N·m) at 2800 rpm
- 1968 Ford
- 1968 Mercury
- 360 hp (269 kW) at 5400 rpm and 420 ft·lbf (570 N·m) at 3200 rpm
- 1968 Shelby Cobra GT500
- Cobra-Jet 4V, 10.8:1 — 335 hp (250 kW) at 5200 rpm and 440 ft·lbf (597 N·m) at 3400 rpm
- 1968 Ford Mustang
- 1968 Mercury Cougar
- 1968 Shelby GT500KR
- Cobra-Jet and Super Cobra-Jet 4V, 10.6:1 — 335 hp (250 kW) at 5200 rpm and 440 ft·lbf (597 N·m) at 3400 rpm
- 1969-1970 Ford Mustang
- 1969-1970 Mercury Cougar
- 1969 Ford Fairlane
- 1969 Ford Torino
- 1969 Mercury Cyclone
- 2x4V, 10.5:1 — 355 hp (265 kW) at 5400 rpm and 420 ft·lbf (570 N·m) at 3200 rpm
- 1967 Shelby GT500
428 Cobra Jet
The 428 Cobra Jet, launched in April 1968, was a version of the 428 FE engine built for performance rather than cruising smoothness. The 428 Cobra Jet could be made on a regular production line, not requiring the exacting tolerances required by the 427. The 428 Cobra Jet has greater low-end torque than the 427, thanks to its longer stroke. The Cobra Jet used a strengthened version of the 428 block with an extra main bearing webbing and thicker main caps than the standard block. The engine was underratedat 335 hp (250 kW) at 5200 rpm. The 428 Cobra Jet actually produced 400 to 410 hp (299-306 kW)
428 Super Cobra Jet
The 428 Super Cobra Jet used the same top end as the 428 Cobra Jet but the crankshaft, connecting rods, and pistons are different. Cast high-performance pistons and a different crankshaft were used, as well as heavy 427 “Le Mans” connecting rods with capscrews instead of bolts for greater durability. An engine oil cooler was standard equipment with the Drag Pack and 3.9 or 4.3 rear end gear ratios This engine was also underrated at 335 horsepower (250 kW). There is no horsepower or torque difference between the 428 Cobra Jet and 428 Super Cobra Jet.
Source: Wikipedia
