Firewall heater hose grommets....
Mrcj001
#1
Post by Mrcj001 »
Do have these installed right?
I can't remember if they installed from the outside in or the inside out. I have had it apart for a while.
1970 XR-7 351C non/AC
Royce
Re: Firewall heater hose grommets....
#2
Post by Royce »
I think the hoses go through the firewall with no grommets. Where did you get those?
XR7-G Registrar
Cougar Bill
#3
Post by Cougar Bill »
I think the 70 is the only one to get them. If I recall they were reversed...
1970 XR-7 428 Ramair 4 speed (now under restoration)
1970 Eliminator Boss 302
1969 XR-7 428 R-code 4 speed
1969 Std. 428 R-code C-6
1969 XR-7 Convertible 351 AOD
1969 XR-7 Convertible 428 C6
1969 XR-7 351 5 speed "RestoMod" New 525Hp "pacemaker"
https://www.youtube.com/watch?v=SBkOzr7N13Y
1968 XR-7 302-4v 4 Speed (J-code) Painted and under construction
1967 XR-7 302 & AOD Green- Wife's Cat
www.cougarbill.com
Mrcj001
#4
Post by Mrcj001 »
Royce wrote:
14 Sep 2018, 07:54
Hey Royce,
I remember that there was one missing. But it did have grommets there. But it seemed that the grommet stuck out more.
These came from Mustangs Unlimited.
Mrcj001
#5
Post by Mrcj001 »
Yes, this is a 1970 with out A/C
Its seemed that the grommet stuck out further.
I`ll reverse one tonight and see if that works.
I just want it right because this heater core / dash / instrument cluster restoration is a PAIN IN THE A**
Mrcj001
#6
Post by Mrcj001 »
I found this pic and if I remember , this is what they looked like.
Royce
#7
Post by Royce »
Apparently they are in stock - learned something new today, thanks!
http://www.deadnutson.com/heater-hose-f ... ommet-set/
XR7-G Registrar
Cougar Bill
#8
Even us old "wrenches" learn something new... I do like to learn every day.
Heck I even repeat a grade or 2!
www.cougarbill.com
70b302cat
Supporting Member
Supporting Member
#9
Post by 70b302cat »
Here are the ones on the Waco Eliminator.
Dave
Eliminator Registrar eliminator@cougarclub.org
Mercury Cougar Eliminator Registry
CCOA # 7558
CCNE # 08
70 Convertible 351C 4V Close ratio
70 Cyclone Spoiler 429 SCJ 4 speed Drag Pak
70 Eliminator B302 4V Close ratio
70 Eliminator B302 4V Wide ratio Super Drag Pak Cat
70 Eliminator 428 SCJ 4 speed Drag Pak
85 Capri ASC McClaren 5.0 5 speed
Mrcj001
#10
Post by Mrcj001 »
Yep... had them in backwards.
Man what a juggling act to the heater box, hoses and wire installed at the same time
Use lots of soapy water on the hoses while fishing them through the new grommets and firewall.
