1970 351c 4v Headers
JacobRutherford
#1
Post by JacobRutherford » 27 Feb 2018, 15:49
Looking to put some headers on my cougar and was wondering if anyone could point me in the direction of a good set of long tube headers.
wawazat
Re: 1970 351c 4v Headers
#2
Post by wawazat » 27 Feb 2018, 16:07
I used Doug's for the transplanted 351C in my 1969. They cleared the steering box but required some Zbar mods and some clearance of the bell housing. They angle down a bit too much at the collector too. I'm not real impressed overall.
1969 Cougar convertible restomod
canted 393
#3
Post by canted 393 » 27 Feb 2018, 17:00
Try FPA headers www.fordpowertrain.com, spendy but very high quality headers. Stay away from hookers the exhaust port mismatch is terrible.
Tomcat
#4
Post by Tomcat » 28 Feb 2018, 10:22
I remember an article written back in the day that dyno'd a 351C once with stock exhaust manifolds then again with headers. The difference in preformance was minimal. The people that did the test were really impressed by how well the stock manifolds flowed.
Tomcat
1970 Eliminator purchased new 11/20/69
R.B.Phillips
#5
Post by R.B.Phillips » 01 Mar 2018, 11:07
I can corroborate the observation Tomcat cites. My 351C M-Code dipped into the 13s (barely) using the cast iron stock manifolds. However, if you have the money to burn in the budget, call the FPA guys on the phone and grill them on whether their header require a bracket to lower the power steering cylinder and its ram. That was always the dumbest feature of longtubes on Ford intermediates - and still IS, for all the national brands. Maybe FPA figured out a solution.
canted 393
#6
Post by canted 393 » 01 Mar 2018, 12:52
R.B. on FPAs you still need the drop bracket.
JacobRutherford
#7
Post by JacobRutherford » 01 Mar 2018, 13:34
Thanks for the replies.
R.B.Phillips
#8
Post by R.B.Phillips » 03 Mar 2018, 12:33
Ugh! A man can still dream....thanks for the confirmation.
canted 393 wrote:
01 Mar 2018, 12:52
1969XR7Vert
#9
Post by 1969XR7Vert » 03 Mar 2018, 13:28
I run the Hooker Ceramic Coated Comp's for 2V heads and have been into the high 12's with Isabel at over 4K lbs.
1969XR7Vert
#10
Post by 1969XR7Vert » 03 Mar 2018, 13:29
P.S. Buy the bulletproof drop bracket from WCCC. Spendy but no chance of ripping the nutserts out of the frame rail.
