I need a header suggestion
Sounnder
#1
Post by Sounnder » 06 Jan 2018, 16:38
I have the 69 4v 390 in my Cougar and am considering going to headers when I rebuild my exhaust system. Anyone have good experiences with headers at a reasonable price?
Thanks!
1969 Eliminator 390 / C-6
2017 Ram 6.7 2500 4x4 Limiited
catlover
Supporting Member
Supporting Member
Re: I need a header suggestion
#2
Post by catlover » 08 Jan 2018, 08:52
Sounnder wrote:
06 Jan 2018, 16:38
Thanks!
Most ford guys like FPA headers.
You might want to check this out. /www.bing.com/search?q=fpa+headers+musta ... =QBLH&sp=5
There is never time to do it right, but always time to do it over
67 Cougar restomod
69 Elim. 428 SCJ orange/ white
CCOA 7574
xr7g428
Site Admin
Site Admin
Contact:
#3
Post by xr7g428 » 08 Jan 2018, 11:34
You will need to get one head drilled in one location to make them fit, but the 428 Cobra Jet exhaust manifolds will make a nice improvement without the continuous hassle of headers.
Legendary Cougar Magazine
Currently in the Cat House
427XR7
#4
Post by 427XR7 » 10 Jan 2018, 17:21
I'm in complete agreement with Bill regarding the installation of the cast iron CJ exhaust manifolds in lieu of headers. They fit properly and retain some residual value, as well. Every time I've used headers it's been a disappointment. They leak, rust or cause some other system problem. Never again. I use 289 Hipo manifolds on my small block cars, too.
Royce
#5
Post by Royce » 11 Jan 2018, 10:25
I just got through spending 8 hours installing the header bolts in a set of JBA headers for a car with a 494CI FE (427 with a 4.25" crank). It was an absolute ass whipping due to the owner deciding not to spend the extra $200 to have his Edelbrock heads drilled with the CJ bolt pattern. I agree with Bill's suggestion, the CJ manifolds are the way to go despite costing 50 horsepower. You can get that power back by installing a 4.25" crankshaft in your 390. Check out Barry Robotnick's website for parts packages.
XR7-G Registrar
Sounnder
#6
Post by Sounnder » 12 Jan 2018, 16:04
SO where would I acquire the CJ Bolt Pattern and is there a link to Barry Robotnick's website?
xr7g428
Site Admin
Site Admin
Contact:
#7
Post by xr7g428 » 12 Jan 2018, 22:31
Easiest thing to do is to get the manifold and then mark the head with the manifold installed except for the one bolt.
canted 393
#8
Post by canted 393 » 13 Jan 2018, 08:50
