Motor mount question
rcode
#1
Post by rcode »
Hi All,
I recently had the car on a hoist and noticed the engine bay support bar (goes under the oil pan) is awfully close to the oil pan and actually has slightly rubbed at some point. Anyone else with a 428 ever noticed this? I am wondering if the mounts have sagged. They appear to be ok but I'd appreciate hearing from any other owners.
Thanks,
rcode
69 XR7 CJ Black plate Triple R car, original selling dealer:
Star Lincoln Mercury, Glendale, CA
03 Cobra (ordered new)
LaBelle Ford LaBelle, Fl
"Tonight, We Ride"!
tinman
Re: Motor mount question
#2
Post by tinman »
Does your oil pan have reliefs like this?
http://www.428cobrajet.com/sites/defaul ... -pan-6.jpg
Mike
rcode
#3
Post by rcode »
Geez, not sure tinman, I'll check tomorrow. Thanks for the heads up!
rcode
"Tonight, We Ride"!
rcode
#4
Post by rcode »
Yes the reliefs are there. They appear to be for the steering linkage though. The pan is stamped FoMoCo and has 8 22 C on it. I'll see if I can get some numbers off the engine mounts.
Thanks
rcode
"Tonight, We Ride"!
rcode
#5
Post by rcode »
Just checked the mounts and plates too, DIZA-6038-CA. So they are correct too. It appears at some point someone may have jacked the car up using the crossbar. Could be possible it's slightly bent. Have to see if I can find another.
rcode
"Tonight, We Ride"!
rcode
#6
Post by rcode »
Update: Purchased a stock crossmember and it fit's with plenty of clearance. I suspect my original thought may be true. Some PO or mechanic jacked the f/end up under the crossmember and it gave somewhat.
rcode
"Tonight, We Ride"!
Mike_B_SVT
#7
Post by Mike_B_SVT »
I wonder if that is the problem I have with mine as well...
Mike B.
CCOA # 9553
Cat Bites Man!
rcode
#8
Post by rcode »
Mike,
The advice I give is do not purchase an after market unit, They're not even close. Find a good used original and strip/repaint.
rcode
"Tonight, We Ride"!
Mike_B_SVT
#9
rcode wrote:Mike,
rcode
Good to know, thanks!
Mike B.
CCOA # 9553
Cat Bites Man!
