70 Cougar AOD conversion w/ FMX tranny question
Cougrrr
Re: 70 Cougar AOD conversion w/ FMX tranny question
#101
Post by Cougrrr »
Thanks Andy. Yes I’ve been pencilled in for spring.
1969 351W Convertible
Car tour: https://youtu.be/QOVDOv6GVhU
Project thread: https://bit.ly/2n8GvKI
Artic Cat
#102
Post by Artic Cat »
Planning this as a winter project on my 69 Vert (351W FMX, 3.25 TrueTrack). To take the mystery and worry out of it I'm going with LenTech's street cruiser with a tighter 1st and 2nd gear set and 1800-2200 stall converter. It might be a bit more expensive but doing the install yourself should help keep the costs down.
Chuck
Contact:
#103
Post by Chuck »
I'm not trying to hijack this thread but I also own a 1967 Mustang GTA. It has a 5 liter crate motor (345 HP) with fuel injection, 2500 rpm stall convertor, AOD and a 9-inch with Auburn True-Track posi and 4.11 gears. This is my daily driver and I commute between Phoenix and Tucson once per week. I usually take Hwy 79 which goes north from Tucson, through Florence, AZ and dumps onto Hwy 60 near Florence Junction, AZ. From there I go west until the hwy turns freeway and I get to my office. I prefer going the back way as the speed limit is 65 and that is right at 2700 RPM for me (besides there are Way-y-y-y fewer cars).
I'm here to ask if anyone has done a gear swap in their cars using Motive Gear sets. I have them in my 67 and there is always a slight whine under accel or decel. I rebuilt the rear-end a few years ago and it is neither louder now or quieter now, still the same. I also did the rear-end in the 70 Cougar with 3.50 ratio and a locker (not Auburn but the other one). I have not yet driven the car but I adjusted the gears on the 3.50 pumpkin about 20 times to be sure I had it right. I did the same procedure as I did on the 4.11. My concern is that maybe something was not quite right with the way I did it. If Motive Gears (4.11:1) are known to make some noise then I'm good, otherwise I may redo both of them.
Here are some pics of the tooth pattern I did when I rebuilt the 4.11 set...
4.11 View "A"
4.11 View "B"
We also entered a pumpkin carving contest! My entry is on the left...
I did not win the contest, but at least there was no whining about it!
Chuck
1956 Ford Thunderbird - Fiesta Red and White top
1967 Ford Mustang GTA Coupe - Wimbledon White and Black vinyl top
1970 Mercury Cougar Eliminator - Competition Yellow, 428 CJ, 4-speed
1986 Ford Mustang SVO - Medium Canyon Red
Chuck
Contact:
#104
Post by Chuck »
Ooops, I guess I do not have any of the 70 Cougar pumpkin, that I can find anyway.
catlover
#105
Post by catlover »
The pattern looks good, but most times the whine comes from the bearing preload, the pinion bearings mostly.
There is never time to do it right, but always time to do it over
67 Cougar restomod
69 Elim. 428 SCJ orange/ white
CCOA 7574
Chuck
Contact:
#106
Post by Chuck »
Too tight or too lose on the pinion bearings? That would indicate a preload set incorrectly.
Gaugster
#107
Post by Gaugster »
I'm not as experienced in differentials but been reading up lately. One basic source of noise is the gear tooth combinations. In the case of a 9" the 4.11:1 is an ideal set whereas the 3.50:1 ratio as a "common factor of 5". I guess this means multiple teeth contacting simultaneously. So the fact that they both make noise makes me think it's not related to the gears themselves but another area. Perhaps what Catlover was suggesting.
John - '68 Cougar XR7 390 FE (X-Code) 6R80 AUTO
Chuck
Contact:
#108
Post by Chuck »
Common factor of 5 means that every 5th revolution, the same teeth are meshing.
9F91H581221
#109
Post by 9F91H581221 »
Your contact pattern looks ideal. I've installed a few Motive Gear and some just won't run silent. They do seem quieter than Richmond.
I haven't heard of pinion bearings making noise when in good shape and properly adjusted.. Worn or loose bearings will be the cause of noise.
Chuck
Contact:
#110
Post by Chuck »
Maybe I'll pull it and recheck everything. I recently built a 31-spline unit for the Cougar. 3.50 Gears and Eaton locking posi. I had the gear sets out and back in probably 35 times before I was happy with the pattern and preload. I'm getting pretty good at setting them up now. I have not yet run the Cougar as the engine/trans is scheduled to be reinstalled on Tuesday, Nov 23, 2021. Then we'll give it the old "smoke test".
Return to “Classic Cougar Maintenance Restoration and Repair”
