67-73 Cougar Sequential Turn Signal Trouble Shooting Thread
Attyhyde
New Member
Re: 67-73 Cougar Sequential Turn Signal Trouble Shooting Thread
#391
Post by Attyhyde »
cougarsunlimited.net wrote: 19 May 2020, 09:53
Attyhyde wrote: 18 May 2020, 18:33 Everything works fine except the far right passenger side light when the right blinker is on. The bulb lights up when the light switch is pulled
Try swapping the bulb with one of the other bulbs to determine if the bulb or socket is the problem.
Thanks, Vic. I swapped bulbs with the inside socket and now both work perfectly.
Stagss62
#392
Post by Stagss62 »
Hi, I have a 70 cougar with the original blinker module and when I activate the right turn signal the Sequential blinker Works fine, but when I activate the left turn signal all of the blinker lights activate together not sequentially. When I turn on the hazard lights the left side blinks all together while the right side is sequencing.I was wondering what might be causing this.
Contact:
#393
Post by cougarsunlimited.net »
Stagss62 wrote: 13 Jun 2020, 19:32 Hi, I have a 70 cougar with the original blinker module and when I activate the right turn signal the Sequential blinker Works fine, but when I activate the left turn signal all of the blinker lights activate together not sequentially. When I turn on the hazard lights the left side blinks all together while the right side is sequencing.I was wondering what might be causing this.
The left left side is operating in brake light mode. This could be due to one or more problems:
1. missing flashing left front signal on green/white wire at the controller in the trunk
2. bad ground for left front turn signal
3. wrong bulbs (drawing too much current) in left side marker lights - try unplugging them to see
4. bad sequential controller (shorted output transistors or open diodes)
Stagss62
#394
Post by Stagss62 »
Thank you Vic for the help. I found out that the rear left marker light does not flash with the blinkers. It seems like somebody added a ground so it only stays on solid when the lights are turned on. Also should the right side be sequencing when the emergency flashers are turned on? I was also wondering if the relays on the blinker module should be clicking because they don’t seem to be doing anything? I disconnected all four and nothing seemed to change.
bmwhd1
Contact:
#395
Post by bmwhd1 »
Vic will steer you straight but I'll add that on my '70, replacing both mechanical flashers with his new digital units cured a myriad of ills. Well worth the money.
Todd
'70 Conv, 351C-4V, T5z
Lone Star Cougar Club
Contact:
#396
Stagss62 wrote: 17 Jun 2020, 21:47 Thank you Vic for the help. I found out that the rear left marker light does not flash with the blinkers. It seems like somebody added a ground so it only stays on solid when the lights are turned on. Also should the right side be sequencing when the emergency flashers are turned on? I was also wondering if the relays on the blinker module should be clicking because they don’t seem to be doing anything? I disconnected all four and nothing seemed to change.
On the 1970-1971 Cougars (and other Fords), the side marker light ground is routed through the front turn running light filament.
Because of the low resistance of this filament, this routing causes the side markers to flash with the turn signals.
But when the headlights or running lights are turned on, the side marker lights flash the opposite of the turn signals
(OFF when turn signals are on, ON when turn signals are off. A modification such as you describe may affect the turn
signal operation unless it was done to the lights in all four corners and then the side lights will no longer flash during turn signal operation.
The side marker adapter kit, that I designed, rewires the side marker lights to use a ground wire for each bulb.
The circuitry retains the original flashing feature while allowing the use of LEDs in the front and side bulbs.
With the early original sequencers, the emergency flashers do not sequence the rear lights.
Sometime in 1971-72, this changed (on board marked 2L7-0135-01) where the rear lights do sequence during emergency operation.
The original "LittleFuse" brand relays, used after 1/1/70, commonly fail where the contact arm breaks off - rendering them useless.
These relays were used to eliminate the voltage drop inherent to the transistors used in the original sequencers.
These sequencers will still work when the relays are disconnected.
Stagss62
#397
Post by Stagss62 »
So I finally got time to try and diagnose the issue and I finally found it. The quarter panel had been previously replaced and the body shop that did it must have cut the wire that’s runs from the front marker light to the blinker module. Thank you Vic for all the information it really helped me diagnose this one.
PacificaXR7GT
#398
Post by PacificaXR7GT »
68 XR7. Mechanical sequencer replaced with Cougars Unlimited unit. Turn signal relay is original. Hazard relay is original. Rear center lamp won’t flash with turn signals or hazards. Thinking maybe my hazard switch is bad? Here’s what’s going on:
Engine running, headlights off:
Brakes:
All three brake lamps on each side illuminate when brake depressed.
Turn signals:
Turn signal indicators flash each way.
Front turn signals flash each way.
Rear turn signals skip center lamp and flash 1,3 in each direction.
Hazards:
Turn signal indicators both flash.
Front turn signals both flash.
Rear turn signals both skip center lamp and sequence 1,3 on both sides.
Engine running, headlights on works the same as above.
Steve
CCOA #9998
1968 XR7 GT 4 speed - Augusta Green / Dark Ivy Gold
whitelightning777
Supporting Member
Supporting Member
both turn signals totally don't work
#399
Post by whitelightning777 »
I have a 1968 base model cougar. I have the solid state sequencing box in the trunk, new solid state flasher under the dash & everything worked.
Out of the blue, the turn signals totally stopped but the brakes, hazards and rear lighting with the headlights all work just fine.
I replaced the turn signal switch but this resulted in no change whatsoever. That orange wire with the inline fuse has power.
All parts are from WCCC.
Is the inline fuse holder itself to blame?
1968 cougar base model w 302 + C4 tranny & open rear end.
motorfinger
#400
Post by motorfinger »
cougarsunlimited.net wrote: 26 Apr 2013, 19:20
69ragtopcat wrote:I have tail lights turn lights,but no brake and hazard lights.new switch and all.have no power going to brake light switch,but all fuses are good,the only one that seems to have no power is the little 5amp one.dont know where to begin
Check the circuit breaker that feeds the brake light circuit. It controls the power for both
the brakes and hazard lights.
I have a 69 cougar and I've been looking for this little 15 C.B. for the hazards and brake lights and I cannot find it for the life of me. I have the same issue, just recently installed plasma LED with the kit from WCCC along with the flasher unit replacement. Worked for a little while, but then, all of a sudden, No flashers and No brake lights. Signals work, running light work. Front flasher lights work. I have to believe that it is this 15 C.B. Does it have to be reset or replaced?
thanks friends!!!!
Stace
Return to “Classic Cougar Maintenance Restoration and Repair”
