67-73 Cougar Sequential Turn Signal Trouble Shooting Thread
Bluestuff
Re: 67-73 Cougar Sequential Turn Signal Trouble Shooting Thread
#381
Post by Bluestuff »
My recommendation would be to stop chasing your tail, and buy a complete LED set up from wccc and install it all.
The improvements are out standing better and you will know every thing is working !
MikaelVroom
#382
Post by MikaelVroom »
cougarsunlimited.net wrote: 18 May 2020, 14:57 First, the front bulbs should be 1157A not 1156. Correct this first!
Oops, I replaced the backup lights at the same time and got my numbers mixed up. The fronts are correct!
Also, a 552 flashes too fast and may not allow enough time for the 2nd and 3rd bulbs to turn on.
However, since only the inner most bulb on each side is turning on in brake light mode, it points to a bad sequential controller/connector.
What’s the recommended flasher? The WCCC site referenced the 552 flasher so that’s what I went with.
Contact:
#383
Post by cougarsunlimited.net »
Use a D0WY-13350-AR for both the turn signal and emergency flasher.
It has a longer (~1.2 second) cycle time instead of .3 to .4 second cycle time of a 552 flasher.
Attyhyde
New Member
#384
Post by Attyhyde »
I have a ‘68 and have installed the LED upgrade kit and the solid state sequential unit from WCCC. Everything works fine except the far right passenger side light when the right blinker is on. The bulb lights up when the light switch is pulled so I’m sure the bulb is fine. Is this most likely the connection at the socket or is the wiring the more likely culprit?
Contact:
#385
Attyhyde wrote: 18 May 2020, 18:33 Everything works fine except the far right passenger side light when the right blinker is on. The bulb lights up when the light switch is pulled
Try swapping the bulb with one of the other bulbs to determine if the bulb or socket is the problem.
MikaelVroom
#386
Tinkered with it a bit more, suddenly the left center joined the party as well? But inconsistently. I started wiggling wires to see if anything was loose, and in the process wiggled the sequential box. Stuff started pouring out of the box, so I popped it open to find...
I don't know, can anybody spot anything wrong? :lol:
Time for an upgrade.
Contact:
#387
MikaelVroom wrote: 20 May 2020, 05:53 Tinkered with it a bit more, suddenly the left center joined the party as well? But inconsistently. I started wiggling wires to see if anything was loose,
You can reuse the black plastic case - after cleaning.
Hopefully, the red and black connectors can be separated and are not corroded.
If they are, replacements are available.
MikaelVroom
#388
I cranked and yanked and pried on those connectors quite a bit and couldn't get them to budge. I have some Weather Pack connectors lying around from another project I may use instead.
Contact:
#389
MikaelVroom wrote: 20 May 2020, 10:10 I cranked and yanked and pried on those connectors quite a bit and couldn't get them to budge. I have some Weather Pack connectors lying around from another project I may use instead.
Unfortunately, Weather Pack connectors won't match the original connectors as used on the original or upgraded sequential controller.
I had these pigtails made up to solve this problem:
C9WY-13H366-AR pigtails.jpg (128.08 KiB) Viewed 468 times
bmwhd1
Contact:
#390
Post by bmwhd1 »
MikaelVroom wrote: 20 May 2020, 05:53 Tinkered with it a bit more, suddenly the left center joined the party as well? But inconsistently. I started wiggling wires to see if anything was loose, and in the process wiggled the sequential box. Stuff started pouring out of the box, so I popped it open to find...
Holy F! It's a miracle any bulb anywhere did anything.
Todd
'70 Conv, 351C-4V, T5z
Lone Star Cougar Club
Return to “Classic Cougar Maintenance Restoration and Repair”
