Door locks when I shut them
bsqparker
Re: Door locks when I shut them
#11
Post by bsqparker »
I think its similar to the bottom one in that pic
Royce
#12
Post by Royce »
It's the one that was broken in my latch. Ace has a multitude of different springs, I suggest you take a good one with you and match it up the best you can. If that fails, you can use any spring from Ace that is similar wire diameter to fabricate what you need.
XR7-G Registrar
bsqparker
#13
Post by bsqparker »
I took the passenger side out yesterday. Got it on the bench. The rod that controls the up and down door lock has no spring on it. I have searched the web a bunch of times and have seen a few glimpses of a little spring or spring clip but nothing 100% for sure. So frustrating because everything else is working perfectly on that latch.
bsqparker
#14
Post by bsqparker »
This is about the best picture I can find. I circle the area and pointed to the spring I need.
This Spring.jpg (45.24 KiB) Viewed 122 times
Ruffrider
Supporting Member
Supporting Member
#15
Post by Ruffrider »
Well mine unlock when I shut them. The found the door key does not open a locked door!!! Off to a locksmith.
67 XR 7 Gray 289 auto
70 Orange / Black Vert 351 5 speed
74 International Scout II total renovation (sold) :D
78 Scout II torn down to frame getin there
97 2500 4x4 Suburban
2015 Ford 4x4 350 dually Desel
Al Bundy
#16
Post by Al Bundy »
Ruffrider wrote: 17 Nov 2021, 18:30 Well mine unlock when I shut them. The found the door key does not open a locked door!!! Off to a locksmith.
Hold the button in when you close it.
1968 XR7 F code - diamond blue/blue - SOLD
1968 XR7 J code - black/red
gah
#17
Post by gah »
I have a question related to this lock problem. Which Phillips stubby socket does one use to get a FIRM grip on the screws used to fasten the lock mechanism to the door post ? The one I have isn't 'blunt' enough to seat properly and deep enough into the screw, so I'm not able to get a good grip on it, and thus remove it.
Thanks for your help on this one !
Return to “Classic Cougar Maintenance Restoration and Repair”
