70 vert t5 tranny
Ruffrider
Supporting Member
Supporting Member
Re: 70 vert t5 tranny
#11
Post by Ruffrider »
I was thinking 3.73 so we are both close. Thanks for the reply.
67 XR 7 Gray 289 auto
70 Orange / Black Vert 351 5 speed
74 International Scout II total renovation (sold) :D
78 Scout II torn down to frame getin there
97 2500 4x4 Suburban
2015 Ford 4x4 350 dually Desel
Ruffrider
Supporting Member
Supporting Member
#12
Post by Ruffrider »
Well I guess we were both close. I figured 3.73. Gonna run a 3.20 gear set an see how that does
Thanks. Ralph
wawazat
#13
Post by wawazat »
Tremec has a nice calculator on their site where you enter your relevant car details (trans, final drive, tire dimensions) and it calculates engine RPM.
1969 Cougar convertible restomod
Ruffrider
Supporting Member
Supporting Member
#14
Post by Ruffrider »
Thanks for the info.
Be Safe. Ralph
Ruffrider
Supporting Member
Supporting Member
#15
Post by Ruffrider »
Well have the rear chunk installed an took her out for the first Breck in run. 3:40.1 Not impressed 50 mph at200 in third not much diff in 4th and 5th was not close to 80 mph at 2500 rpm. I sure hope the break in process .improves the the rpm to mph. Have ya'll had the happen to new rear sections. An what is supposed to be above the lower bump stop on rear axle ?
Midlife
Contact:
#16
Post by Midlife »
Ruffrider wrote: 28 Nov 2021, 18:55 Well have the rear chunk installed an took her out for the first Breck in run. 3:40.1 Not impressed 50 mph at200 in third not much diff in 4th and 5th was not close to 80 mph at 2500 rpm. I sure hope the break in process .improves the the rpm to mph. Have ya'll had the happen to new rear sections. An what is supposed to be above the lower bump stop on rear axle ?
RPM to MPH is entirely controlled by gears, so no, it will not improve with time.
Let me check your shorts!
http://midlifeharness.com
bmwhd1
Contact:
#17
Post by bmwhd1 »
Can you share any more specifics on which gear ratios you have in the T5, which speedo gear you're using, etc.? I'm not following why you're not seeing a difference between 3rd, 4th, and 5th.
Todd
'70 Conv, 351C-4V, T5z
Lone Star Cougar Club
xr7g428
Site Admin
Site Admin
Contact:
#18
Post by xr7g428 »
I doubt this is it but I had a bad clutch in a BMW that slipped in overdrive. Of course that finished it off in a hurry.
Bill Basore,
Fuel Sender Rebuilding, Gauge Testers, and Reproduction Cougar Parts:
Desert Classic Parts
The only magazine ever dedicated to the Classic Mercury Cougar
Legendary Cougar Magazine
Currently in the Cat House
Ruffrider
Supporting Member
Supporting Member
#19
Post by Ruffrider »
Thanks for the replies.
Todd how can I find the gear ratios in my tranny. Can I enter the numbers on the side in a index somewhere?
Thanks. Ralph
Return to “Classic Cougar Maintenance Restoration and Repair”
