68 G valance
There were only 619 XR7-Gs built. They were built along side the Shelby Mustang, and were available with every engine and transmission offered in 1968, (except the 427). This was the first Cougar to be a part of the Hertz Rent a Racer program. If you have any information about these rare cats, this is the place to share. The XR7-G registry is maintained by Royce Peterson.
68 hertz
Supporting Member
Supporting Member
68 G valance
#1
Post by 68 hertz »
Any body have pictures of fog light pockets,I’m wondering if you have two holes in the top of the pocket or one,
Randy ,Syracuse NY
fordnutz
Contact:
Re: 68 G valance
#2
Post by fordnutz »
There's one to mount the light through and another that a rubber grommet sits in with the wiring for the fog light, and two drain holes near the bottom.
You do not have the required permissions to view the files attached to this post.
Thanks, Scott Ferguson
President, Fordnutz Cougar Club
E-mail President@Fordnutz.org
Visit the Fordnutz Cougar Club on the web http://www.fordnutz.org
Past Chairman, Cascade Cougar Club
http://www.CascadeCougarClub.com
Past Chairman, Cougar Club of America
http://www.cougarclub.org
68 hertz
Supporting Member
Supporting Member
Re: 68 G valance
#3
Post by 68 hertz »
Thanks,that’s what I’ve seen before,mine doesn’t have the raised mounting area and only one hole.it appears it will take only the marchal light, the Lucas would require modification to the valance [CCCGallery][/CCCGallery]
Randy ,Syracuse NY
Royce
Re: 68 G valance
#4
Post by Royce »
All of them should be identical. Scott's photo shows a reproduction I think. I thought Bill had the drawing but I don't see that one posted here:
https://classiccougarcommunity.com/xr7- ... /#more-294
XR7-G Registrar
fordnutz
Contact:
Re: 68 G valance
#5
Post by fordnutz »
I have never seen a G front valance like the picture of the one you posted, Randy. But maybe there was a difference between those getting Marchal and Lucas lights.
The picture in my post is of the original reproduction fog light buckets that I had reproduced. The original version was pretty much an exact reproduction of the buckets out of a G front valance with Lucas lights. The later repro versions were modified with the wiring cut-outs on both sides to help the laser cutting production (the metal pieces were mirror images right to left, but the wiring holes were on the right side of the buckets when put together in the originals, later repros had holes in both sides).
I have been looking through my pictures as I'm sure I must have pictures of one of the valances out of the car, without fog lights installed. If I find something I will post it.
hipo65
Re: 68 G valance
#6
Post by hipo65 »
The one that is pictured is the first version that would be on a Hertz or early G with just one hole. The second style has a plate welded in the center that gives the light about a 1/4" more room and has a hole with grommet for the wiring.
fordnutz
Contact:
Re: 68 G valance
#7
Post by fordnutz »
Here is the schematic of the G front valance from the Mercury Master Parts Catalog.
And a picture of a Lucas fog light installed in a Hertz G.
68 hertz
Supporting Member
Supporting Member
Re: 68 G valance
#8
Post by 68 hertz »
It’s definitely original to the car, it is an early hertz car it’s the only one I’ve seen like it,only the marchal light will fit , the schematic sent appears to be what I have a single hole with wire through the hallow bolt ,I’ll have to get some marchal lights , others were long gone.[CCCGallery]800|1067|2019|5328
Randy ,Syracuse NY
fordnutz
Contact:
Re: 68 G valance
#9
Post by fordnutz »
Good luck finding the Marchals. I've never looked into them, so I have no idea how hard they are to come by.
68 hertz
Supporting Member
Supporting Member
Re: 68 G valance
#10
Post by 68 hertz »
I see wccc has one
Randy ,Syracuse NY
