Everything you wanted to know about '67 Sequential Signals
coachJack
Re: Everything you wanted to know about '67 Sequential Signa
Post by coachJack » 28 Sep 2013, 14:23
Unfortunately the 69 and 70 taillight systems are vastly different than the 67. I helped another Cougar enthusiast with his 69 looking at the 69 wiring diagrams from WCCC web site.
Vic Yarnberry has a web page for troubleshoting the 69-73 sequential taillights http://www.thuntek.net/cougars_unlimited/69seqts.htm
Hope this helps.
Coach Jack
whitepink59
Post by whitepink59 » 28 Sep 2013, 15:26
coachJack wrote:Unfortunately the 69 and 70 taillight systems are vastly different than the 67. I helped another Cougar enthusiast with his 69 looking at the 69 wiring diagrams from WCCC web site.
Hope this helps.
Coach Jack
Thanks Jack.
1970 XR7 Cougar convertible, orange with brown interior and black roof, 351W.
1959 Cadillac Coupe deVille, white with pink interior.
beechboy90
Post by beechboy90 » 29 Nov 2013, 18:09
I have a 68 Cougar, and while under the dash tried to locate the Flasher can / turn signal relay. Unable to find it, does someone have a pic taken from the floorboard of where the can is located? Any picture that would show where I should be looking would be great. I am assuming the reason my turn signals do not work, is because the Blinker relay is missing or wired wrong by previous owner.
devildog
Post by devildog » 30 Nov 2013, 00:13
This is the back side, the front facing you in the dash has some circuit breakers and what not. Mounted to the WW motor bracket.
Greg - 1967 A code Field Car (didn't even have the luxury of a barn)
beechboy90
Post by beechboy90 » 30 Nov 2013, 10:17
HA HA .. That sux.. I purchased a "Flasher Can" that said it was for my Cougar ( I am used to seeing them on my VW BUS) and I was looking all over for a stupid barrel flasher. Back to the floorboard!
coachJack
Post by coachJack » 30 Nov 2013, 10:26
To help troubleshoot your issue I have a few questions:
1. Does the emergency flashers work? - If they do work, then the K7 Turn signal relay is not your issue, indicating a high probability that your turn signal switch is bad.
2. Have you verified that the 15 amp inline fuse is OK?
3. If the emergency flashers are not working, have you verified that the circuit breaker is OK?
4. Assuming power is now going to the turn signal switch, have you verified that circuit 458B has power when in left turn mode?
5. Likewise, have you verified that circuit 458 has power when in right mode?
Note circuits 458 and 458B provide the input power to the K7 Turn signal relay.
If you really suspect your issue is the K7 relay, you can bypass the relay as a test by disconnecting the K7 harness and placing a jumper wire across circuits 458 and 459. Circuit 459 will provide the input power to the Sequential Motor.
Hope this helps.
Good Luck.
Coach Jack
coachJack
Post by coachJack » 30 Nov 2013, 10:31
BTW,
In Devil Dog's picture, I am pretty sure his is of a 67 and the two relays shown with the wires are the K5 and K6 relays which your 68 does not have. The relay hanging off to the left of the picture is the K7 relay.
Coach Jack
AJSenior
Post by AJSenior » 01 Feb 2014, 10:59
Coach,
Thanks for the informative document in the 67 Cougar Sequential Lights which I have worked my way through to try get my 68 lights to work, but I am still seriously confused and not getting there with the sequential turning lights. All the light functions do what meant to (I think), so maybe you can steer me in the right direction in the turn lights. I have installed a solid state replacement, and removed the sequent motor. The blue wire from the solid state in connected to the K10 relay at 514 (blue). Configured as such, the turn light activate the inside tail lights only (no sequencing). The emergency switch activates both center tail lights. The combination of the two (right or left turn, plus emergency) activate both side in sequential mode. Looks great, but I'm sure its not correct. If I switch the blue lead from the solid state to K10 into the 436A connection (yellow), then the sequencing activates (on both sides) on the emergency switch only, and the turn lights only activate the inside tail lights.
Any ideas ?
Andrew
68 Cougar RX7
58 Fairlane 500
AJSenior
Post by AJSenior » 01 Feb 2014, 11:01
with reference to the earlier posts, I have a single barrel flasher under the dash
Andrew
68 Cougar RX7
58 Fairlane 500
coachJack
#20
Post by coachJack » 01 Feb 2014, 20:13
AJ,
The Solid State Sequencer does away with the sequential motor (as you pointed out) but it also does away with the sequential relays and the K10 relay.
You are correct that the blue wire from the solid state sequencer connects to connector P79 (which was plugged in to K10) on circuit #514. Circuit 514 should have power when the hazards are off, and are de-energized when the hazard swith is on.
Your last post mentions you have a flasher barrell? The Cougars do not use flasher barrels as the Sequencer motor expects constant voltage to the circuit. You should have a 3 wire Turn Signal relay C8WY-13A366-A for a 68 Cougar. (Note this is a differnt part number than a 67)
I would check the voltage on circuit #459 Orange-Green wire at the Solid State Sequencer in 3 different modes:
1. Hzsw OFF, Turn signal in Right
2. Hzsw OFF, Turn Signal in Left
3. Hzsw ON, Turn signal in Center
I suspect that in your case, #3 above will show a higher voltage than #1 or #2. This would indicate a problem with the turn signal switch. If however all 3 tests have the same voltage, then the Solid State Sequencer is suspect.
