A snapped bolt... oh no...
This is the place for your Cougar adventure stories. Do you drive your Classic Cougar? Tell us about it!
ssava
Contact:
#1
Post by ssava » 05 Jan 2018, 15:02
So... my son and I decided to try and get the heater working. First thing we were told to do was to replace the thermostat.
A simple enough thing that we (amateurs) could do for only $5.99.
Unfortunately, it didn't work out that way.
One of the two bolts we had to take off to get to the thermostat SNAPPED.
We tried everything. Reverse screw sets. Drilling. Bolt loosening sprays.
Nothing worked.
In desperation, we called a friend who had a friend who was a mechanic. He came over and tried for an hour to drill the bolt out.
No luck.
"You know", he said, "it's easier to replace the intake manifold.
Oh. Okay. Let's try that.
Now here's the thing. For Christmas... I got (or really Esmerelda got) new Valve covers.
So we had fun putting those on the day after Christmas... and I guess we got comfortable working on her enough to try the thermostat.
Now we're in over our heads.
Fortunately we got the intake manifold in the next day and my buddy and his friend went to work (with my son and I watching and learning).
We had to scrape off the old gasket and clean out the antifreeze
Ready for the new gasket
New gasket in
We had to remove the distributor to get the new manifold in
The bolts were then TOO short (2 inch) and we needed 2 1/4 inch bolts. But the auto store didn't have any. Nor did Home Depot.
So we bought 2 1/2 inch bolts and added washers for now.
Then... since we were putting in a new intake... we added a 4 barrel carburetor
By now, it was 11pm and we were finding that the boxes did NOT include many things like couplers and throttle return springs.
So now she sits waiting for the last bits to come in.
I'm hoping by the end of the day we'll have her up and running again.
I'm told she'll have a few more horsepower when it's all done too.
Our $5.99 project suddenly became a $599 project overnight... ack.
And at the end of the day... my buddy looks at the old thermostat and says "This looks like it works just fine"
Sigh
"Esmerelda"
Franklin, TN
cougarrand
Re: A snapped bolt... oh no...
#2
Post by cougarrand » 05 Jan 2018, 15:45
That's how it always starts!
Randy Feuillerat
67 XR7 GT 390 4V
68 390 X code XR7
68 XR7-G 302 2V
70 XR7 Convt 351 2V
70 Eliminator 351 4V 4 speed
MrEos
Contact:
#3
Post by MrEos » 05 Jan 2018, 16:23
It's not a project unless you get a new tool out of the job....
DaveK
#4
Post by DaveK » 05 Jan 2018, 18:06
Heat the manifold with a torch and you might be able to back that bolt out.
Royce
#5
Post by Royce » 05 Jan 2018, 18:47
I've broken that bolt many times. I normally drill it out with a 1/8" drill followed by 7/32" followed by 1/4" then tap the hole 5/16" - 18.
XR7-G Registrar
ssava
Contact:
#6
Post by ssava » 05 Jan 2018, 19:16
Thanks all. I thought you'd share my misery/experience here.
As I've already got the new intake in... I've got the old one (with broken bolt still inside) off to the side in the garage.
I'm trying to keep all the original parts as we change them... just in case.
"Esmerelda"
Franklin, TN
CatsRock
#7
Post by CatsRock » 06 Jan 2018, 06:59
Been there done that too, luckily I was able to soak mine in pb blaster and use a reverse drill bit to back mine out. With that being said, although your project took a huge leap in price, the experience for you and your son can't have a price tag to it. And good move keeping the originals. Enjoy the ups and downs (at the end of the day lol ) cause now when you pop the hood you can say, yea we did that :smoke:
08 Suburban
1973 XR7 351Q Vert
EX 1975 Cougar XR7
EX 1972 Cougar XR7 Vert
EX 1967 Cougar
JETEXAS
Contact:
#8
Post by JETEXAS » 06 Jan 2018, 09:49
Now you need headers to complement the increased airflow from your new carb and manifold!
ssava
Contact:
#9
Post by ssava » 06 Jan 2018, 15:08
JETEXAS wrote:
06 Jan 2018, 09:49
For real? Like will this be a problem?
Or would new headers be advised to compliment the new carburetor?
"Esmerelda"
Franklin, TN
ssava
Contact:
#10
Post by ssava » 06 Jan 2018, 15:10
She’s done!
"Esmerelda"
Franklin, TN
