2 post or 4 post lift?
This is the place to kick a few tires, drink a few beers, and tell a few tales.
Wallgeye
#1
Post by Wallgeye » 17 Jul 2017, 15:42
Hey everyone. I am in the process of moving to a new home. Close in 2 weeks. There is a 42x24 heated shop that comes with the house. I am toying with buying a lift. Co-worker has a 2 post, talked to an outfit at the street machine nationals last weekend that sells 4 post. Thoughts on what would be preferred for restoration work? Big pluses on the 4 post I was looking at is it can be moved around the shop, only needs 110v outlet and no requirements on slab thickness. Is about 1 or 2k more expensive though. I have plenty of room overhead. 12ft high door and ceiling is probably 18 foot in the front of the shop. For some reason drops to about 12 or 16 feet in the back half.
Don Rush
Contact:
Re: 2 post or 4 post lift?
#2
Post by Don Rush » 17 Jul 2017, 15:53
2 post for working on a car, four post for storing one in the air.
badcatt
#3
Post by badcatt » 17 Jul 2017, 16:07
If you don't know how the floor was done you will need to cut out sections and poor heaver footings for 2 post lifts. But having a 4 post I can tell you a 2 post is nice for doing work on your car.
Neal Jacobson.
1970 XR-7 White "Ginger"
1970 XR-7 Convertible Blue
1971 XR-7 Bright Blue with Blue "Up Beat" interior
See ya on the hiways,
they are an entire banquet
- Mark Twain -
xr7g428
Site Admin
Site Admin
Contact:
#4
Post by xr7g428 » 17 Jul 2017, 16:44
12 foot is high enough. I would get a two post. You can do more with it. Plus you can always add storage lifts later.
Legendary Cougar Magazine
Currently in the Cat House
HarstenePointe
#5
Post by HarstenePointe » 17 Jul 2017, 21:58
I have two 4-post lifts which I use to store 4 Cougars in 2 garage bays. They are re great for that, but a 2 post lift is really what you would want to work on cars.
67 XR7 Cinnamon Frost - parents bought it new
68 XR7 Nordic Blue - X code
69 XR7 Convertible Black - 351/4V
70 Std Medium Gold - 351/2V
70 Eliminator Comp Gold - 351/4V 4-speed
Wallgeye
#6
Post by Wallgeye » 24 Jul 2017, 01:56
Thanks for the advice. The last lift I worked under was a center post lift in high school shop. I will figure out how thick the slab is and go from there.
xr7g428
Site Admin
Site Admin
Contact:
#7
Post by xr7g428 » 24 Jul 2017, 10:20
Some two post lifts have an extended base and don't require the additional thickness of the slab. Consider the size of the contact patch of the tires on the pavement and the contact patch of the lift.
pvan
#8
Post by pvan » 17 Aug 2017, 09:11
I have a 4-post Bend-Pak and love it, but I have no doubt that a 2-post would be better for working on a car. Although it was an option, I wasn't comfortable putting mine on casters to roll around. First, because I currently have a garage that has a slight pitch to it. Second, because without the base anchored, it seemed like it would be far less stable.
9F91H581221
#9
Post by 9F91H581221 » 02 Oct 2017, 22:48
both
BigNuge
#10
Post by BigNuge » 03 Oct 2017, 14:47
For what its worth, I have a 2 post in my shop and I love it! I considered the 4 post, but it looked tough for actually working on cars. The 230v circuit wasn't bad at all. I ran 10/2 to it, easy peasy....
68 XR7
