In tank fuel pump
In tank fuel pump
Post by DaveK » 20 Dec 2017, 13:20
Sitting here at work with some time on my hands I got to thinking - would it be possible to put an electric fuel pump in the tank of my XR-7 while maintaining the low fuel level sensor?
I think the pump would be easy enough to attach to the pickup tube, however, the question is how to get power to the pump?
So I did a little digging online and found this: ... -terminals
There might be enough space on the mounting flange of the sending unit to mount two of these to power the pump.
What do you guys think?
Is there a better way to get power through the mounting flange?
Local Hero
Re: In tank fuel pump
Post by Local Hero » 20 Dec 2017, 13:49
I've never seen a submersible fuel pump that produced low enough pressure for a carbed engine. Those are designed for efi where fuel pressures on the 30-40 psi range are commonplace as opposed to the 4 or 5 that a carb takes. You'd definitely need some sort of regulator unless efi is in your future as well.
With that said, your link is a nifty little gadget that I'll keep in the back of my mind should I find myself in that situation.
Buckeye Boys Rod & Custom - East
Anyone can restore a classic... it takes a real man to cut one up.
Post by DaveK » 20 Dec 2017, 13:59
Yeah, I'm thinking about EFI. I checked the price to ship those little things and it isn't cheap.
DHL Express Shipping ($38.50 ex)
Express Courier International ($42.57 ex)
Registered Post International ($17.84 ex)
Supporting Member
Supporting Member
Post by cj750 » 18 Jan 2018, 16:25
Ford CFI systems circa '83-'84 used two pumps. A low-pressure in-tank pump and a high-pressure external pump. The in-tank pumps produced 6-8 psi, IIRC. A little bit high for a carb, but easily handled by a regulator.
Every post I make is made with a request for corrections. I'm here to learn.
1969 Cougar Eliminator 351 4V, yellow
1970 Cougar Eliminator 428SCJ, black
Post by BossElim69 » 19 Jan 2018, 07:03
The Aeromotive tank is another option. ... ontent=pla
Brian Carpenter, President CATS classic Cougar club
67 Cougar road course racer
67 Cougar project car
67 Cougar GT
68 XR7-G trailer queen restoration.
68 Restomod
69 Boss 302 Eliminator
69 XR7 390 survivor
69 XR7 428CJ 4spd
70 Boss 302 Mustang
1993 Harley Davidson
2004 F250 diesel
2004 Jeep Overland 4.7L H.O.
78 Ford F 150 Ranger
08 Cobalt SS
Post by mfc133 » 19 Jan 2018, 08:55
I've been eyeing up the Spectra EFI tank for my future switch to fuel injection:
Amazon link: ... rds=F28AFI
The advantage of this one is the pump/sender assembly mounts under the car where the stock sender would be. So there's no wires/fuel lines/bulkhead fittings in the trunk.
1968 Cougar Standard, 302 4V, auto
Post by Allen68 » 19 Jan 2018, 09:15
Another option is FiTech has a pump that you mount in your factory tank. It does require a hole to be cut and fuel lines in the trunk though. I bought one but have not installed yet. I will say also FiTech has very good customer service or at least very prompt answering questions.
