Issues with a 215/70/14 tire?
drewk86
Post by drewk86 » 11 Dec 2017, 09:16
I'd like to run a set of Mastercraft Avengers on my 68. It still has it's factory 14X6 rims and it currently running a 205 series tire. But the Avenger starts at a 215...would there be any fitment issues going from a 205 to a 215?
cyclonelou
Re: Issues with a 215/70/14 tire?
Post by cyclonelou » 11 Dec 2017, 11:15
That tire should fit as it's just slightly larger in diameter. To be sure , find a junk 215, have it mounted and put it on the car. Then you'll know for sure.
Post by Don Rush » 11 Dec 2017, 11:28
Thats what I often run, fit perfect and look good.
Yorgle
Post by Yorgle » 11 Dec 2017, 21:34
I've always had 215s on my 68. They fill the wheel openings perfectly.
1968 XR-7 Augusta Green, J-Code, 5 litre, Autolite 6100, 5 spd, convertible with heated seats, cruise control and rear sway bar.
BTW, I think electronic ignition is pointless.
