best of both worlds ; torque on a budget (diet )
Royce
Re: best of both worlds ; torque on a budget (diet )
#11
Post by Royce » 06 Nov 2017, 06:31
A 427 Ford weighs about 100 pounds less than a 428 CJ due to its aluminum intake. Those weights are off, someone is on drugs if they believe a 429 - 460 is 10 pounds lighter than an FE. Go pick up a 460 crankshaft and compare it to an FE crankshaft. Ditto the heads or block.
The 351M / 400M is an odd duck engine, with its bellhousing pattern matching a 460. Not much in the way of performance parts available, you would likely have to build custom headers yourself to put one in a Cougar.
XR7-G Registrar
ClawIt
#12
Post by ClawIt » 07 Nov 2017, 06:34
Royce wrote:
06 Nov 2017, 06:31
Two engine builders I have worked with since "back in the day" would not bore a 'M' block.
R Code
#13
Post by R Code » 07 Nov 2017, 08:12
bob hess wrote:
31 Oct 2017, 17:42
--- Working with a 68' 390/ 4 speed cat --
Mystified why you'd want to pull the FE in a rare/unique cat and replace it with any other combo. Even if you found something that you thought would work a little better: who cares?
- Chris
1967 Std 4 speed conversion
1989 Merkur XR4Ti
