Who's done an AOD swap?
JETEXAS
Contact:
Re: Who's done an AOD swap?
#11
Post by JETEXAS » 17 Oct 2017, 07:26
For those who have done the AOD swap, what sort of mpg increase did you see afterward?
9F91H581221
#12
Post by 9F91H581221 » 17 Oct 2017, 08:28
Around town it's the same. Highway cruising is up to around 5 more. Plus reduced engine noise because of 33% less rpm in OD. It's a great addition for Cougars that get driven. The stock shifter in the Cougar works with the AOD too.
jcbingcougar
#13
Post by jcbingcougar » 17 Oct 2017, 19:34
Also depends on your rear gears. With a 351C 4V, AOD and 3.25 gears, I get around 20 mpg on the highway.
Jeff Bingaman
1970 Cougar
1956 Ford F100
1960 Dodge Phoenix
2017 Mustang GT Premium
2017 F150 Platinum
http://www.cascadecougarclub.com
