Replacing XR7-G dual exhaust - 390GT
propayne
Contact:
Re: Replacing XR7-G dual exhaust - 390GT
Post by propayne » 03 Jan 2017, 14:12
More advice please - I am getting ready to order my exhaust from NPD and their catalog says that the H-pipe is 2" on Cougars before 12/11/67 and 2 1/4" on Cougars from 12/11/67.
I'm pretty sure I need the 2" but my G was produced on May 6, 1968 and I want to make sure I am ordering the correct pieces.
Attached are some photos of the exhaust manifolds that are now on my engine.
So which H-pipe do I order?
- Phillip
1969XR7Vert
Post by 1969XR7Vert » 03 Jan 2017, 14:19
Royce wrote:I've done the weld - a - bolt - to - the - muffler thing several times without owning a welder. I put marks on the mufflers where I wanted the bolts, and handed the mufflers and the bolts to the muffler shop guy. He's got a welder.
I made stainless steel sheet stock "U" shapes with the proper sized hole so that a 5/16" self-threading bolt would cut its own threads into it. I welded those to my Magnaflow stainless mufflers. This exactly emulates the stock muffler mountings as I recall.
You can see one of the U-shapes in the right of this photo:
Royce
Post by Royce » 03 Jan 2017, 16:37
Measure the round hole in the manifold. If they truly make one that fits in 2 1/4" then that sounds like what you wanted.
The big change was replacing the RH exhaust manifold heat valve on the early 390GT's with a spacer on the rest of the '68 model year cars. I was unaware a change of diameter happened.
propayne wrote:More advice please - I am getting ready to order my exhaust from NPD and their catalog says that the H-pipe is 2" on Cougars before 12/11/67 and 2 1/4" on Cougars from 12/11/67.
- Phillip
XR7-G Registrar
propayne
Contact:
Post by propayne » 03 Jan 2017, 17:23
Thanks Royce -
I've been doing more checking and I think that the ordering info in the catalog is misleading. I think all '68 390GT exhaust manifolds are 2" and that the early/late change they are talking about only applies to the heat valve you mentioned.
- Phillip
hipo65
Post by hipo65 » 17 Feb 2018, 10:17
Phillip, did you end up getting the NPD exhaust system and if so how did it fit? Has anyone else installed the 390 exhaust system from Waldon's or WCCC and how do they fit?
propayne
Contact:
Post by propayne » 17 Feb 2018, 20:18
Yes, I had some time constraints so the easiest and quickest thing to do was order the full exhaust system from NPD.
I delivered the Cougar and exhaust plus all the hangers, clamps, etc. to the muffler shop and when I picked it up the technician said he had a few fitment issues and had to do some finessing and welding. But he was able to install in in a couple of hours.
I've put about 600 miles on her since and so far so good.
- Phillip
1967 S Code
Post by 1967 S Code » 18 Feb 2018, 14:17
propayne wrote:
17 Feb 2018, 20:18
- Phillip
How about some pictures Philip. I’m interested in seeing the Coral Gables “G” all spruced up.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
Standard, 302 4V, XR7G Console, XR7G Front Valance
propayne
Contact:
Post by propayne » 18 Feb 2018, 14:34
I would really love to find some more stuff from that Coral Gables Mercury dealership.
I may have posted these, not sure - but here a few more pics.
Running real well now (knocks on wood).
- Phillip
xr7g428
Site Admin
Site Admin
Contact:
Post by xr7g428 » 19 Feb 2018, 15:42
I am loving this! Great job!
Legendary Cougar Magazine
Currently in the Cat House
propayne
Contact:
Post by propayne » 19 Feb 2018, 17:46
Thanks Bill - I'm really enjoying the process.
- Phillip
