Replacing XR7-G dual exhaust - 390GT
propayne
Contact:
#1
Post by propayne » 31 Dec 2016, 07:06
I've had the 390 for my G rebuilt, along with the C6, radiator, etc. and I need to replace my entire exhaust system.
I have a few questions and I would appreciate some feedback -
Since this is a G it all will end up dumping out of the factory style "pipe within a pipe" chrome exhaust tips - so I assume I would need to stick with the factory 2" exhaust?
I would like to improve the exhaust if I can. I was thinking of getting everything that is included in the OEM setup except for the mufflers and substituting a better performance muffler, like a Magnaflow, etc. Is that doable?
And I assume that since the G's exhaust goes straight out the notched rear valence, my exhaust shop will need to cut off the "down turns" and weld on my chrome tips?
Again, any and all advice is much appreciated :beerchug:
- Phillip
catlover
Supporting Member
Supporting Member
Re: Replacing XR7-G dual exhaust - 390GT
#2
Post by catlover » 31 Dec 2016, 07:56
Phillip, Sounds like you have a plan, should not be a problem for a custom exhaust shop.
There is never time to do it right, but always time to do it over
67 Cougar restomod
69 Elim. 428 SCJ orange/ white
CCOA 7574
Royce
#3
Post by Royce » 31 Dec 2016, 10:21
The 390GT manifolds and H pipe are the worst part of the system.
Summit Racing sells a nice set of mandrel bent 2 1/4" pipes for 68 Cougar. Change to 428CJ manifolds and then the H pipe will also be 2 1/4". You can use aftermarket mufflers by welding bolts to the rear face of each muffler. That way the aftermarket muffler can bolt to the factory hangers.
The reproduction tips can be necked up to 2 1/4". The larger pipe for the entire run will help performance considerably.
XR7-G Registrar
propayne
Contact:
#4
Post by propayne » 01 Jan 2017, 12:16
Thanks guys -
Guess I should have mentioned that I decided to stick with my original 390GT manifolds and the engine is already back-in-the-hole, so whatever I do will have to include those.
So, the larger 2 1/4" pipes wouldn't work with 390GT manifolds?
Royce
#5
Post by Royce » 02 Jan 2017, 11:09
The pipes from Summit start at the back side of the mufflers so they will be fine. The 390GT H pipe is 2" diameter. I suppose that you could have one made in bigger pipe but it would still have to be reduced to 2" right where it comes out of the manifolds.
propayne wrote:Thanks guys -
XR7-G Registrar
propayne
Contact:
#6
Post by propayne » 02 Jan 2017, 11:36
Thanks a lot Royce, I appreciate the information.
Could you elaborate a little more on what you mean by "The reproduction tips can by necked up to 2 1/4"?
How exactly is that done?
- Phillip
1969XR7Vert
#7
Post by 1969XR7Vert » 02 Jan 2017, 12:01
propayne wrote:Thanks a lot Royce, I appreciate the information.
- Phillip
Not to speak for Royce but he probably means a good exhaust shop can "swage" (stretch) the tip ends up to the required size.
ClawIt
#8
Post by ClawIt » 03 Jan 2017, 07:25
Phillip,
I was in your situation years ago. I ran the 2" H-pipe and intermediates into Flowmaster 40s that had the same in/out orientation and were within an inch of the same length as the original mufflers. Summit has 2.25" tailpipes that fit Cougars without the turn down, so 2" in 2.25" out on the mufflers. I would hesitate welding the tips on because after 5+ years of use the outside edges started rusting or you got a dent in the edge. Royce's answer about the mounting works, I didn't have a welder so made a sheet metal half circle and used that with the muffler clamp at the back of the muffler to the hanger. Stretching the tips can be done by inserting a pipe expander (borrow from auto parts), but the tailpipe metal will expand easier then the tip steel. I just needed about 16th " on the tailpipe then slid the tips into the pipe and clamped. The flowmasters have a great rumble at idle and high speed pull was way better.
Jim
propayne
Contact:
#9
Post by propayne » 03 Jan 2017, 09:53
Very helpful stuff - thanks Jim!
- Phillip
Royce
#10
Post by Royce » 03 Jan 2017, 13:35
I've done the weld - a - bolt - to - the - muffler thing several times without owning a welder. I put marks on the mufflers where I wanted the bolts, and handed the mufflers and the bolts to the muffler shop guy. He's got a welder.
XR7-G Registrar
