Purpose of floor pan drain plates
On what day in 1966 did the secret Cougar marketing program begin? April 1st, April Fools day. On what day in 1968 did the Cobra Jet 428 become available in the Cougar April 1st April Fools day. Is there a message in there somewhere? This is the place to find out.
Yorgle
Contact:
#1
Post by Yorgle » 18 Apr 2013, 13:28
I'm confused. Those oval shaped covers that attach to the front and rear floor pans with two screws are called by most vendors "drain plates" or "drain covers" but considering that they are covered with sealant and screwed down to the floor, how do they drain anything? What are they really there for?
1968 XR-7 Augusta Green, J-Code, 5 litre, Autolite 6100, 5 spd, convertible with heated seats, cruise control and rear sway bar.
BTW, I think electronic ignition is pointless.
70 Cougar
Re: Purpose of floor pan drain plates
#2
Post by 70 Cougar » 18 Apr 2013, 16:43
I remember reading something somewhere that stated the floor drain holes were put there by the designers to allow the priming solution to drain out of the body when the shell of the body was dipped and submerged in the primer solution. I'm pretty sure these cars weren't dipped in primer but were sprayed with primer instead at the factory, therefore the floor drain holes might have been carried over from previous methods in the past.
- Steve O
1970 Mercury Cougar
2004 SVT Cobra
Don Rush
Contact:
#3
Post by Don Rush » 18 Apr 2013, 16:49
To drain after the rust proof dunk.
G68
Supporting Member
Supporting Member
#4
Post by G68 » 18 Apr 2013, 17:52
Don Rush wrote:To drain after the rust proof dunk.
LOL!! Judging from some of the floor pans I've seen over the years that "rust proof dunk" wasn't very successful! They must have drained too much of said rust proofer out of them!
"I feel more like I do now than I did yesterday"
1968 Cougar 289 4V
2018 F-150 XLT Sport 5.0L Coyote
2017 Mustang (Sally) 2.3L 310 HP EcoBoost
Mike_B_SVT
#5
Post by Mike_B_SVT » 18 Apr 2013, 17:55
Yorgle wrote:I'm confused. Those oval shaped covers that attach to the front and rear floor pans with two screws are called by most vendors "drain plates" or "drain covers" but considering that they are covered with sealant and screwed down to the floor, how do they drain anything? What are they really there for?
I wondered the same thing for the longest time! I was like "drain plug"?? Why would you want to plug up the drain? No wonder they rusted out with all the drains plugged up!
Only fairly recently did I read about the whole "dunking" process of priming / treating the bare bodies by the factory. Same with all the wierd ribbing / grooves on the floor pans and other panels - their purpose is to channel the dunking fluids to the drain holes. IIRC, I read about it in a recent issue of Hemmings Muscle Machines - they mentioned it in an article about replicating the factory paint process for acurracy in the paint details on an Olds 442 convertible (IIRC). When I read that it was a very "Ah HA!" moment for me :-)
Mike B.
CCOA # 9553
Cat Bites Man!
ccarney69
#6
Post by ccarney69 » 18 Apr 2013, 21:49
Ok, since we're talking drain plugs, when did they start putting date codes on them? I'm taking apart an A17 built 69 and the plugs have a date of 12 5 on them. So I went to look at the dates on the plugs on the H26 built 69 and no dates. Just curious, would assume about Jan when new mandates were implemented.
1968 GT-E 427 Standard Nordic Blue/Black Décor, driver
1969 XR7 R Code 4 Speed Yellow/Black Top Black Interior, current project no.1
1969 XR7 Q Code C6 Green/Black Top Dark Ivy Green Interior, current project no. 2
CCOA #8275
MACC
1969XR7Vert
#7
Post by 1969XR7Vert » 19 Apr 2013, 06:44
Oh, that's easy. You remove them when you want to let the salt water out of the floorpan after Hurricane Isabel put your car under water.
Wait.
That was just my car.
Nevermind.
J_Speegle
#8
Post by J_Speegle » 19 Apr 2013, 21:11
Plugs were an engineering left over IMHO from the typical Ford design of the floor panels (for those cars - more expensive models- that were dipped)
Cougars uni bodies were not dipped like T Birds or Lincolns) just a spray top and bottom (bottom from jets mounted below track) with plenty of areas missed. :(
