1968 Convertible Conversion
Yorgle
Contact:
Re: 1968 Convertible Conversion
#31
Post by Yorgle » 14 Mar 2014, 18:48
Looking good. Will they be welded to the valance?
1968 XR-7 Augusta Green, J-Code, 5 litre, Autolite 6100, 5 spd, convertible with heated seats, cruise control and rear sway bar.
BTW, I think electronic ignition is pointless.
1967 S Code
#32
Post by 1967 S Code » 15 Mar 2014, 06:45
1969XR7Vert wrote:Fab work! FABulous FABrication Steven! :beerchug:
mo2872 wrote:I'll echo FABio's comment, Steven. Nicely done.
Yorgle wrote:Looking good. Will they be welded to the valance?
Thanks guys. The buckets will be welded to the valance. Here are some pictures of the buckets tack welded in place and a test fit of a fog lamp.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
Al Bundy
#33
Post by Al Bundy » 15 Mar 2014, 07:05
You must be doing good work Steven, you're starting to make me regret not keeping them and doing it myself. :buck:
1968 XR7 J code - black/red
1967 S Code
#34
Post by 1967 S Code » 15 Mar 2014, 08:03
Al Bundy wrote:You must be doing good work Steven, you're starting to make me regret not keeping them and doing it myself. :buck:
Al I really appreciate you selling me the fog lights. I probably would not have made this mod without Lucas lights. :beerchug:
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
1967 S Code
#35
Post by 1967 S Code » 28 Mar 2014, 10:45
I did a test fit of the valance today. The fog light buckets cleared everything so I removed the valance and its back to the welding table for the final welding.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
CATHOUSE
#36
Post by CATHOUSE » 29 Mar 2014, 18:56
Maybe it's just an angle in the above photo but the bucket on the right looks to be closer to the center of the valance than the bucket on the left. Based on the drop down in the bumper and its relationship to the top of the bucket.
1967 S Code
#37
Post by 1967 S Code » 29 Mar 2014, 19:53
Randy you are correct. The buckets were worked off of the centerline of the valance so they are good. The bumper needs to shift over about 5/16 of an inch towards the drivers side. The car was hit on the passenger side at some point in its life. The bumper brackets/bar still is bent. After that fix is done the drop down in the bumper for the license plate opening will look better. I also didn't have the valance completely bolted in place when I took the photo. My main reason for the test fit was to make sure the backs of the buckets cleared the bottom of the radiator support.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
Yorgle
Contact:
#38
Post by Yorgle » 30 Mar 2014, 06:47
Looks good, Steven, but I think you should add some drain holes for all the snow and slush that will get packed in there. ;)
CATHOUSE
#39
Post by CATHOUSE » 30 Mar 2014, 10:27
Steven, good to know that you are on top of it. I thought about the bumper not being on quite right but it is a bit hard to tell as the far right side is cut off in the photo. Good to hear that the valance fit with no issues.
1967 S Code
#40
Post by 1967 S Code » 30 Mar 2014, 20:45
Yorgle wrote:Looks good, Steven, but I think you should add some drain holes for all the snow and slush that will get packed in there. ;)
Jody I did think about drainage. We don't get near the snow here in South Carolina that you get but we get plenty of rain and car washing. I'll take a picture of the bottom of the buckets, I left a 1/4 inch gap the length of the bucket. This is for the drainage. I liked this idea when I was doing the fabrication better that just holes. The bottom of the bucket is angled towards the bottom inside of the valance so water or anything should drain well. When I'm done I'll get a template made up and send it to you.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
