1968 Convertible Conversion
1967 S Code
Re: 1968 Convertible Conversion
#201
Post by 1967 S Code » 18 Jun 2017, 20:44
Here is a photo of the burled walnut material that I will be using for my dash face.
I really like the color and the pattern of the laminate.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
1967 S Code
#202
Post by 1967 S Code » 28 Jun 2017, 17:07
Here is my test fit of my burled walnut on my gauge cluster. I have a little more sanding to get the clearances I want. After the sanding I'll move on to the openings for the wiper switch, turn signal, belts and brake. Once everything is cut and sanded I'll remove the clear plastic protector over the material.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
1967 S Code
#203
Post by 1967 S Code » 18 Jul 2017, 11:25
I've been continuing with my dash restoration and modification. One thing that was bothering me was the indicator lenses for the dash. They were tired and faded. While shopping for school supplies I found a rather inexpensive solution to my indicator lens problem. I purchased a pack of notebook tab dividers, The dividers have transparent colors of red, green, blue and yellow.
I removed the worn indicator lenses from their bezels at cut the tab dividers to fit over the lenses. I inserted the cut tab dividers into the bezels followed by the factory lenses. The end result is a clean transparent lens in the proper colors to correspond with the indicator.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
xr7g428
Site Admin
Site Admin
Contact:
#204
Post by xr7g428 » 18 Jul 2017, 11:43
Brilliant!
Legendary Cougar Magazine
Currently in the Cat House
wish
#205
Post by wish » 18 Jul 2017, 13:15
As Bill said, "Brilliant!". I was looking for something for my shift indicator as the plastic shield in there was covered in goo and proceeded to return to particle form on cleaning. This should do just perfectly!
Just my $.02
wish
69 Cougar, That 70s Truck, 84 Cherokee Chief 2dr, 88 Grand Wagoneer, 95 Grand Cherokee,96 Mustang
1967 S Code
#206
Post by 1967 S Code » 18 Jul 2017, 14:10
Thanks guys. The pictures show everything well but the indicators look better in person. I think everything will really look good when I get the LED bulbs I ordered from WCCC's installed. Between this, LED's and the new blue diffusers I installed I can hardly wait to see the end result.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
1967 S Code
#207
Post by 1967 S Code » 22 Jul 2017, 19:44
I finished dressing up the high-beam indicator lens this afternoon. I ordered a used one from WCCC's, even after cleaning it needed a bit more help. A clear tab divider did the trick.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
DieselD
#208
Post by DieselD » 22 Jul 2017, 23:11
Great idea!, thinking outside the box!
I may have to steal this idea from
You when I get to this point in my build.
1968 Standard, 302 2v, 3 speed.
1967 S Code
#209
Post by 1967 S Code » 06 Aug 2017, 15:06
Here is another picture of my dash overlay. I'm getting close to having all 3 of the pieces fitted.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
1967 S Code
#210
Post by 1967 S Code » 19 Aug 2017, 21:13
I'm pretty much complete with my dash overlay. I've been working on installing a mini-tach. Seeing that the Cougar mini-tach is unavailable I opted to use RCCI's Mustang mini-tach.
I follow up with Brian "BAC" on his install and he was great at answering my questions. You can read about Brian's mini-tach here: viewtopic.php?f=3&t=6578&p=68094&hilit=Mini+tach#p68094
The picture below is a test fit with my custom lens using the Cougar clock lens's center. I cut it loose with an exacto knife and mounted to the new lens. The new lens has a green appearance because of the protective coating of the plexiglass. I'll remove the protective coating when I'm sure no more cutting and sanding of the lens needs to be done.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
