1968 Convertible Conversion
1967 S Code
Re: 1968 Convertible Conversion
Post by 1967 S Code » 05 Feb 2014, 16:30
CATHOUSE wrote:
1967 S Code wrote:How do you remove the center padded section and the walking Cougar emblem from the steering wheel pad? Thanks, Steven
As I recall the center piece is just pressed into place. There is a long stud coming off the backside of the piece on each side that fits into a hole in the foam of the main pad. If you have the main pad removed from the steering wheel you can sometimes see the hole from the underside and can then use something like a punch to help push the studs out. If not gently pry from the topside. Either way try to work each side evenly. Once the center piece is removed from the pad I believe that you will need to do a little grinding to remove the Cougar emblem. If you have purchased the reproduction center piece you will see where the studs are on the backside.
Thanks Randy. I disassembled everything last night. It was just as you said. I didn't see the holes on the backside of the pad where the studs are located. I used a small plastic spatula and gently worked from side to side until it came loose. I ground off the little studs on the walking Cougar and it came right off.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
Standard, 302 4V, XR7G Console, XR7G Front Valance
CATHOUSE
Post by CATHOUSE » 05 Feb 2014, 18:05
Good to hear that you got it apart. I had tried several times over the weekend to post the reply but was unable to due to whatever the site problems were.
1967 S Code
Post by 1967 S Code » 09 Feb 2014, 22:57
While tinkering with Top Cat I noticed that there is "in and out" play in the ignition cylinder, about 1/8". When it is pulled out, power is lost to the fan and turn signals and maybe more (radio is missing and the interior lights at the floor have no bulbs). Is there a way to tighten the cylinder so it doesn't have this "in/out motion". The ignition switch barrel (not sure if that's the right name) is secured tightly to the dash by the bezel.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
1967 S Code
Post by 1967 S Code » 02 Mar 2014, 06:16
I received the new aluminum radiator. The one that is in the car is really over sized. It is so long the previous owner cut a notch in the battery tray in order to get it in. So along with changing the radiator I have to replace the battery tray. Not a big deal. Here are some photos of the new radiator.
The price was great also $150 with free shipping.
Here are a couple of pictures of Top Cat in the shop.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
1967 S Code
Post by 1967 S Code » 03 Mar 2014, 20:01
Small things are getting done. I've been working on the steering wheel restoration. I've been pretty set on the direction of the build. I'm going to combine the best styling ques of the GT-E and XR7G. G hood scoop, fog lamps, GT-E black out grille, tail light treatment and grille bars.
Here is the steering wheel pad.
After a good cleaning I dyed it black and painted the walking Cougar emblem gold like the XR7G.
Here are some pictures of the Lucas fog lamps I picked up from Al. I know they are not XR7G correct but the will work for my application and I can stay in the Lucas light family.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
ccarney69
Supporting Member
Supporting Member
Post by ccarney69 » 03 Mar 2014, 22:51
Nice job on the steering wheel pad. I like the direction you are taking with this cat.
1968 GT-E 427 Standard Nordic Blue/Black Décor, driver
1969 XR7 R Code 4 Speed Yellow/Black Top Black Interior, current project no.1
1969 XR7 Q Code C6 Green/Black Top Dark Ivy Green Interior, current project no. 2
CCOA #8275
MACC
leonbray
Supporting Member
Supporting Member
Post by leonbray » 03 Mar 2014, 23:50
2013-09-28 kosmos.jpg (83.87 KiB) Viewed 346 times
The square 8's look good even without recessing them
They'd look even better if they were straight
2013-07 - Autobarn Show.jpg (102.16 KiB) Viewed 346 times
Designed to be driven
1967 S Code
Post by 1967 S Code » 04 Mar 2014, 06:00
ccarney69 wrote:Nice job on the steering wheel pad. I like the direction you are taking with this cat.
Thanks :D
Thanks Leon. I think I'm going to recess them after I make the buckets. The valance that is on the car needs some small body work, so while it's off the car I'll modify it with the buckets.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
Yorgle
Contact:
Post by Yorgle » 04 Mar 2014, 11:30
A GTE-G vert will be extremely cool. Or maybe it should be an XRE-7G. Or maybe XRGTE-7G. Kinda makes the head spin just thinking about it. I'm looking forward to seeing your modifications to the valance for the lights.
1968 XR-7 Augusta Green, J-Code, 5 litre, Autolite 6100, 5 spd, convertible with heated seats, cruise control and rear sway bar.
BTW, I think electronic ignition is pointless.
1967 S Code
Post by 1967 S Code » 04 Mar 2014, 19:11
Yorgle wrote:A GTE-G vert will be extremely cool. Or maybe it should be an XRE-7G. Or maybe XRGTE-7G. Kinda makes the head spin just thinking about it. I'm looking forward to seeing your modifications to the valance for the lights.
Yeah Jody all of those letter combinations can make the head spin. I'm thinking along the lines of G-TC. G for Gurney inspired, TC for Top Cat or top convertible. I did a computer drawing of the fender emblem. It's crude but I was just playing with the Idea.
I'll take plenty pictures of the buckets when I start the metal work. I began the a light weight cardstock mock up today. I fighured it was better than bending a lot of metal to start with.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
