68 standard, restromod driver?
mfc133
Re: 68 standard, restromod driver?
#121
Post by mfc133 »
Nice job! I imagine it's much more fun to drive now with the 4-spd. Plus the money you saved can go to other areas of the car. I've been looking into a T5 swap myself and it definitely has become a costly endeavor.
-Mike
1968 Cougar Standard, 302 4V, auto, Madras Blue
#122
Post by DieselD »
mfc133 wrote:
27 Jun 2020, 17:18
It certainly is more fun and it just feels right. The 3 spd always felt mismatched for the engine. The 4spd is definitely a better match.
You have an auto so that adds to more expense and work to do the T5 swap, maybe an AOD is something to consider? Then again swapping to an AOF might be just a costly as the T5?
Work in progress...
#123
Post by pellets4fuel »
Good work D. Glad you got that pilot bearing thing worked out. I recall mine doing something similar to that once I got to driving it. I had put rebuilt motor in it, new clutch, tranny, etc. Then it sat for years only getting pulled out occasionally to work on things and never really driven. Once I did get it done and started driving it the clutch was acting goofy. I guess I attributed it to surface rust on machined parts. It eventually has squared itself away. I should pull the cover at some point and do a visual.
Hey you need to change your signature line now :)
#16306 1967 Lime Frost S-code, Ivy gold interior built 11-1-66
3.25 Limited slip, 4-speed. Courtesy lights, sports console, whisper-aire, AM-8track, deluxe belts.
