Shock Tower Welding
fishboy
Shock Tower Welding
Post by fishboy » 28 Feb 2018, 10:58
Has anyone welded the inner and outer tower together? I am in the process of welding up the torched grease zerk holes and while I am at it should I weld the inner and outer together? I imagine I should install the export brace first.
1967 Cougar Standard, 4sp, early production
1966 Ford Galaxie fastback, 390
2008 BMW Dinan M5, 630 hp
2002 Ford F-250 Super duty, crew cab
2001 Ford F-150, Waldoch conversion
2013 GMC Denali XL
2014 Roush F-150, 570 hp
Blitz
Re: Shock Tower Welding
Post by Blitz » 28 Feb 2018, 13:16
Not sure about that, but you should definitely consider doing these weld-in plates if you haven't already. There's also a video on that page (featuring my car!) on this topic. And yes actually it sounds like a good idea to put on the export brace (even if it's temporary) to make sure everything stays in the right place while you're doing stuff.
-Andrew Chenovick
Photo/Video guy for WEST COAST CLASSIC COUGAR, INC.
Side Gig: FLYING A PHOTOGRAPHY
RIDES:
-1968 Mercury Cougar: original family owned, Polar White, 289-2V, auto, AC / "Snowball" view project thread
-1973 Opel Manta: 1.9L, 5-speed (restored)
-1991 Mazda Miata: fun driver
-1992 Volvo 240 wagon: classy hauling machine
fishboy
Post by fishboy » 28 Feb 2018, 13:33
Yes I was going to order these and install, it looks like someone in the past put a few weld beads on the inner and outer tower.
2013 GMC Denali XL
BossElim69
Post by BossElim69 » 28 Feb 2018, 13:53
On my track Cougar I weld them together and added pieces to wrap it around and down to the sub frame. plus the filler piece under the upper control arm. This is on a 67 so it doesn't have the full wrap around from the factory. Yes, have the export brace installed while your welding and go back and fourth between the two towers to keep the heat build up down.
Brian Carpenter, President CATS classic Cougar club
67 Cougar road course racer
67 Cougar project car
67 Cougar GT
68 XR7-G trailer queen restoration.
68 Restomod
69 Boss 302 Eliminator
69 XR7 390 survivor
69 XR7 428CJ 4spd
70 Boss 302 Mustang
1993 Harley Davidson
2004 F250 diesel
2004 Jeep Overland 4.7L H.O.
78 Ford F 150 Ranger
08 Cobalt SS
fishboy
Post by fishboy » 28 Feb 2018, 14:18
I cannot tell from the angle of the photo but it looks like the inner "flange" where you would weld them together is smoothed out? the way mine is it has a formed edge where they meet.
2013 GMC Denali XL
scottfzeller
Post by scottfzeller » 28 Feb 2018, 15:15
I did the export brace first followed by welding the plates in. Best think I ever did for my 69.
Scott Zeller
1969 Cougar XR7
CCOA Member# 9559
ROTM December 2016:https://classiccougarcommunity.com/foru ... =33&t=7055
C.A.T.S. Classic Cougar Club - Club Services Director
http://www.catsccc.com
Steve68Cougar
Post by Steve68Cougar » 28 Feb 2018, 20:34
Here's what I did with mine:
I could have done more as others have, but for my mild 289 I decided not to do more for now. I'll probably revisit this area if/when I swap out to an FE. I also put the "dog bone" on the outside frame rails:
As others have recommended, I installed an export brace before I did any welding. I was lucky enough that the shock towers lined up quite well and I didn't have to do any tweaking to the shock towers.
