Stripping Paint
JacobRutherford
Stripping Paint
#1
Post by JacobRutherford » 13 Feb 2018, 12:08
My 70 Cougar's paint is starting to chip off since the previous paint job on it did not have primer under the paint and was just sprayed to the metal. I was wondering what materials I would need to start stripping the paint off and getting it ready for primer. Thanks.
BossElim69
Supporting Member
Supporting Member
Re: Stripping Paint
#2
Post by BossElim69 » 13 Feb 2018, 14:27
Depends on how you want to strip the paint off? Chemical, sanding or media blast. if it's chipping off easy my suggestion first is to try a high pressure washer. You might peel a lot of it off with a washer.
Brian Carpenter, President CATS classic Cougar club
67 Cougar road course racer
67 Cougar project car
67 Cougar GT
68 XR7-G trailer queen restoration.
68 Restomod
69 Boss 302 Eliminator
69 XR7 390 survivor
69 XR7 428CJ 4spd
70 Boss 302 Mustang
1993 Harley Davidson
2004 F250 diesel
2004 Jeep Overland 4.7L H.O.
78 Ford F 150 Ranger
08 Cobalt SS
DaveK
Re: Stripping Paint
#3
Post by DaveK » 13 Feb 2018, 14:41
Personally, I like chemical stripping. Not dust.
preaction
Supporting Member
Supporting Member
Re: Stripping Paint
#4
Post by preaction » 13 Feb 2018, 15:28
First make a decision as to how much paint will be removed, 1 fender, 1 door or the whole car this would give you more info to make the best decision.
67 XR7 6.5 liter auto AC tilt pdb ps thermactor vinyl roof console SS wheels lime frost
Midlife
Contact:
Re: Stripping Paint
#5
Post by Midlife » 13 Feb 2018, 19:01
If it is peeling from bare metal, try a razor blade to remove most of the paint. It's non-toxic and cheap, but somewhat time-consuming. Try it first, and see how it goes.
JacobRutherford
Re: Stripping Paint
#6
Post by JacobRutherford » 13 Feb 2018, 22:14
Going to start with just doing the hood first as that is where the chipping is the worst. Thanks for the replies. Any more recommendations would be appreciated.
BossElim69
Supporting Member
Supporting Member
Re: Stripping Paint
#7
Post by BossElim69 » 14 Feb 2018, 06:31
Posting a picture of the peeling paint would help in guiding you in what direction to take (see link below). Make sure you use a etching or epoxy primer on bare metal as the first step before re-painting. The chipping paint could be from not using an activator in the paint causing it to chip easy.
viewtopic.php?f=2&t=8186
67 Cougar GT
68 Restomod
69 XR7 390 survivor
69 XR7 428CJ 4spd
70 Boss 302 Mustang
2004 F250 diesel
08 Cobalt SS
