Fender to Rocker mount, screwed up.
TCELL
#1
Post by TCELL » 07 Jan 2018, 16:45
I took off my passenger side rocker molding, and noticed that the lower part of the fender had been brazed to the lower rocker panel. Hmmm, that can't be good, wonder why they did that, I thought. Cut the fender loose and proceeded to remove the fender. Upon removal, I could see that the fender had a broken mounting tab. I thought that was it, nope. Today upon further inspection, I see the real issue, no mounting nut thingy.
This how the problem was solved, previously.
This is a picture from the drivers side.
Here is my problem, not sure why the screw hole is there, they may have tried to screw the fender to the rocker.
Anyhow, how do I fix this? Is that mounting nut, replaceable? Kinda looks like it snaps in, maybe?
1970 XR7 351w 2v White w/ Dark Tobbaco interior
TCELL
Re: Fender to Rocker mount, screwed up.
#2
Post by TCELL » 07 Jan 2018, 17:52
Cougar Bill
#3
Post by Cougar Bill » 07 Jan 2018, 18:40
yep called a "caged nut" AMK part.
Many have been welded, your just a screw. Grind flush & install new one.
I use a longer bolt to set new one into place. Fender may require a shim or a bit of love!
1970 XR-7 428 Ramair 4 speed (now under restoration)
1970 Eliminator Boss 302
1969 XR-7 428 R-code 4 speed
1969 Std. 428 R-code C-6
1969 XR-7 Convertible 351 AOD
1969 XR-7 Convertible 428 C6
1969 XR-7 351 5 speed "RestoMod" New 525Hp "pacemaker"
https://www.youtube.com/watch?v=SBkOzr7N13Y
1968 XR-7 302-4v 4 Speed (J-code) On the way to paint!!!
1967 XR-7 302 & AOD Green- Wife's Cat
www.cougarbill.com
TCELL
#4
Post by TCELL » 07 Jan 2018, 18:50
Sweet! Makes me wonder why they went to so much trouble, when it could have been fixed the right way, a lot easier.
Mike_B_SVT
#5
Post by Mike_B_SVT » 08 Jan 2018, 00:11
I feel your pain.
Front Fender Lower Rear Mount Hole.JPG (133.69 KiB) Viewed 507 times
Mike B.
CCOA # 9553
Cat Bites Man!
