Can you change a 1967 door hinge pin without removing the door?
DieselD
Re: Can you change a 1967 door hinge pin without removing the door?
#11
Post by DieselD » 16 Feb 2018, 08:50
Glad I did all this when my body work was done! This does not look like a fun job with a fully assembled door and car.
1968 Standard, 302 2v, 3 speed.
Royce
#12
Post by Royce » 16 Feb 2018, 09:13
The fender comes off easily without removing the front bumper or grille. Just unbolt it from everything. Door adjustment needs to be doe with the fender removed.
XR7-G Registrar
JETEXAS
Contact:
#13
Post by JETEXAS » 18 Feb 2018, 22:15
Thanks for the encouragement, Royce. Getting the fender on and off wasn't as daunting as it seemed. However, I'm glad the residents had vacated before I yanked it.
Once it was off, I loosened all the hinge bolts, then I shut the door and held it in place while my wife tightened the bolts back up.
While the back edge of the door looks great, the front gap seems pretty large, but I'll come back to that when I'm finally ready to paint.
Going to tackle the passenger side this week.
DieselD
#14
Post by DieselD » 19 Feb 2018, 08:35
your fender gap may simply be you fender needing to slide back a bit. You want to alight the door to the body/rocker, hood to the cowl then fender to hood/door.
JETEXAS
Contact:
#15
Post by JETEXAS » 14 Mar 2018, 12:54
I pulled the passenger fender first before attempting that side ... SO MUCH EASIER. With the door shut I was actually able to pull each hinge off and replace them one at a time, and they didn't require any further adjustment afterward.
Very glad this project is finished because the passenger door was a real pain to get closed, and it kept flying open while I was making test drives around the neighborhood.
