Dual Mirrors
Comp Elimn8r
Re: Dual Mirrors
Post by Comp Elimn8r » 07 Jun 2017, 14:44
snafu wrote:
07 Jun 2017, 12:05
Australian passenger door or American passenger door?
USA passenger door ie right side.
1970 Eliminator 351 Comp Green, white trim, auto & Sunroof (1 of 2)
Comp Elimn8r
Re: Dual Mirrors
Post by Comp Elimn8r » 07 Jun 2017, 14:50
Don Rush wrote:
07 Jun 2017, 12:13
snafu wrote:
07 Jun 2017, 12:05
No difference... Keep in mind this was a 1970 Torino mirror that was somewhat of an after-thought. It was not designed for the Cougar specifically but "it works".
Thanks for all the replies fellas it clears up a lot of things, Was this Torino mirror the same measurements on the base? The holes I have in the original door seem to be spaced longer than the drivers one.
Re: Dual Mirrors
Post by Don Rush » 07 Jun 2017, 15:22
Correct, the DS "Torino" mirror base is different in every way including length. If you look at the casting number on the base it should read D0OB-17713-AW, the Ford service replacement part number for the entire kit was D0OZ-17682-D. A 71 mirror will work just as well with a casting number of D1OB-17713-AWA. Many people misinterpret it as D10B-17713-AWA, DI0B-17713-AW or Dl0B-17713-AWA. The 1971-73 base is actually about 1/16" taller, but you will be hard pressed to visually see the difference between a 70 and 71-3. Even when they are placed side by side.
Replaces Ford part # D0OZ-17682-D.
This post may be helpful. https://classiccougarcommunity.com/foru ... ror#p28910
BTW, I like your Avatar pic, it resembles the car on our latest business card.
Comp Elimn8r
Re: Dual Mirrors
Post by Comp Elimn8r » 07 Jun 2017, 16:01
Thanks Don, it looks like another part I will be buying at some time.
Sorry for the copyright infringement, but those green Eliminator pics are the motivation for finishing mine lol.
leonbray
Re: Dual Mirrors
Post by leonbray » 07 Jun 2017, 16:16
Get the convex glass when you order. Adjusting the flat glass to get a good view of the rhs lane pushes it out of the housing, even with a LHD car
Designed to be driven
Re: Dual Mirrors
Post by Don Rush » 07 Jun 2017, 16:41
Comp Elimn8r wrote:
07 Jun 2017, 16:01
No worries, we see those pics all over the net and it brings fond memories of driving the car back.
blaineja
Re: Dual Mirrors
Post by blaineja » 28 Aug 2017, 08:52
Just noticed this post and it got me thinking. Did Ford/Mercury offer the passenger side mirror for the
69 Cougar models as a Dealer installed option? Trying to keep my Cougar as close to original as I can but
would love to justify the passenger side mirror.
Jeff
1969 Yellow XR-7
cj750
Re: Dual Mirrors
Post by cj750 » 28 Aug 2017, 13:54
My '69 has a passenger side mirror that I suspect (but can't prove) was dealer-installed. The paint and patina matched the rest of the car perfectly when I bought it in '83. It was quite a while before I learned it wasn't actually supposed to be there. The numbers on the base identify it as a Mustang part. Which makes sense for cars sold during the '69 model year, prior to the '70 Torino/Eliminator mirror becoming available.
Every post I make is made with a request for corrections. I'm here to learn.
1969 Cougar Eliminator 351 4V, yellow
1970 Cougar Eliminator 428SCJ, black
blaineja
Re: Dual Mirrors
Post by blaineja » 28 Aug 2017, 19:44
Very nice. I always felt that the dual mirrors make the Cougars look better.
1969 Yellow XR-7
Re: Dual Mirrors
Post by Don Rush » 29 Aug 2017, 09:43
No 69 got the PS mirror dealer installed or otherwise as the part was not in production until the first of the 1970 Torinos were made.
