Adjusting the side mirror
There were only 619 XR7-Gs built. They were built along side the Shelby Mustang, and were available with every engine and transmission offered in 1968, (except the 427). This was the first Cougar to be a part of the Hertz Rent a Racer program. If you have any information about these rare cats, this is the place to share. The XR7-G registry is maintained by Royce Peterson.
Rarecat
Post by Rarecat » 17 May 2015, 08:08
Thought I'd wake up this sleepy registry with a quick question for my fellow G owners......what is the best way to adjust the side mirror? Mine points down and is not corrected by a finger push to the top. I'm going to have to adjust it some how so I thought I'd ask the experts before I tore into it.....
Thoughts, insights, snide comments?
1967 Standard Cougar "The Stick Kitty"
1968 Cougar XR7-G
2008 Shelby GT-500 Convertible
fordnutz
Supporting Member
Supporting Member
Contact:
Re: Adjusting the side mirror
Post by fordnutz » 17 May 2015, 10:54
Are the remote cables hooked? If so, is the remote in the proper position? There is a cut out in the door panel that it "locks" in to.
Hopefully I am understanding your question correctly.
Thanks, Scott Ferguson
President, Fordnutz Cougar Club
E-mail President@Fordnutz.org
Visit the Fordnutz Cougar Club on the web http://www.fordnutz.org
Past Chairman, Cascade Cougar Club
http://www.CascadeCougarClub.com
Past Chairman, Cougar Club of America
http://www.cougarclub.org
1967 S Code
Post by 1967 S Code » 17 May 2015, 14:31
As Scott stated above I would start at the remote. When you move it does the mirror move at all?
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
Standard, 302 4V, XR7G Console, XR7G Front Valance
fordnutz
Supporting Member
Supporting Member
Contact:
Post by fordnutz » 17 May 2015, 14:50
I was also thinking that maybe he is talking about adjusting the chrome ring on the mirror. If that is the case, you take a Phillips screw driver and slightly loosen the set screw in the painted end of the mirror and then you can move the chrome ring. Don't forget to tighten it back up when you are done.
Rarecat
Post by Rarecat » 17 May 2015, 16:42
Haven't touched anything yet. I assume the chrome ring is fine in its current position, just the control cables are bound up or something. Will start with the inside and see how it goes. Nothing unique or specific about this style mirror?
1968 Cougar XR7-G
fordnutz
Supporting Member
Supporting Member
Contact:
Post by fordnutz » 17 May 2015, 17:35
It depends on how you look at it. They do not come apart very easily, so be careful you do not get too aggressive.
Good luck with it Frank.
I may have some pictures of one off a car, that might be helpful. Let me know if you want me to post them.
Rarecat
Post by Rarecat » 28 May 2015, 05:55
I had to rotate the chrome ring to get the correct adjustment.....all better now
1968 Cougar XR7-G
fordnutz
Supporting Member
Supporting Member
Contact:
Post by fordnutz » 28 May 2015, 07:14
Glad you got it to work, Frank.
