How to remove 1968 GT-E anodised side mouldings / trim
The GT-E was only available for a few brief months in 1968. Total production would not have kept the assembly line busy for more than a half day. If you know anything about a GT-E, it is important, and this is the place to share it. The GT-E registry is maintained by Jim Pinkerton.
Flasheart
Post by Flasheart » 16 Dec 2017, 14:33
Guys,
I am about to remove the GT-E side trim pieces and have them restored. Before I start, what is the best way to do this? Do I need to access all the cavities to undo the nuts, or is there some way to release the trim from the outside? Any tricks?
Mike
1968 Shelby GT500KR Fastback
1968 Mercury Cougar GT-E, XR7, 427ci
cobrasc427
Re: How to remove 1968 GT-E anodised side mouldings / trim
Post by cobrasc427 » 16 Dec 2017, 18:24
The only trick part is getting into the area just behind the doors and in front of the wheel well openings, remove rear seat, trim panels, water vapor barrier, arm rests, window cranks, and un screw the nuts , unscrew nuts in the trunk well area, and unscrew the screws, simple job, as long as all of the items cooperate
