Spacing of GTE exhaust tips
The GT-E was only available for a few brief months in 1968. Total production would not have kept the assembly line busy for more than a half day. If you know anything about a GT-E, it is important, and this is the place to share it. The GT-E registry is maintained by Jim Pinkerton.
jsv
#1
Post by jsv » 03 Aug 2017, 13:34
About to replace the exhaust system form the original H pipe back with correct Scott Fuller mufflers and the original GTE exhaust tips. Would like to know how far under the valence they should hang, and how far out they should protrude.
Thanks.
ccarney69
Re: Spacing of GTE exhaust tips
#2
Post by ccarney69 » 03 Aug 2017, 20:08
I cannot say that these are installed exactly correct. My car was restored in 1990 and these are the original tips installed. I hope it helps you out.
http://s44.photobucket.com/user/ccarney ... t=2&page=1
1968 GT-E 427 Standard Nordic Blue/Black Décor, driver
1969 XR7 R Code 4 Speed Yellow/Black Top Black Interior, current project no.1
1969 XR7 Q Code C6 Green/Black Top Dark Ivy Green Interior, current project no. 2
CCOA #8275
MACC
jsv
#3
Post by jsv » 04 Aug 2017, 10:23
The photos are very helpful and thank you. Additionally, if anyone has actual measurements, that would also be very useful.
GavinS
Contact:
#4
Post by GavinS » 15 Jan 2018, 22:14
Have you measured the distances from the valance for the tip. Installation? Did Jim Pinkerton have a diagram for measurements?
www.CougarClub.org
You do not have the required permissions to view the files attached to this post.
Gavin Schlesinger
1968 XR7 428 CJ - Lime Frost
1968 XR7 427 GT-E - Wellington Blue
1968 XR7 427 GT-E - Cardinal Red
www.cougarclub.org
Vist me on Facebook.
Stray Cats Mercury Cougar Club
Cougar1
#5
Post by Cougar1 » 16 Jan 2018, 05:32
I do not have written down the actual measurements. Going completely by memory I believe it is 3/8" gap below the valence and 1.5" from the upper back of the tip to the flange on the valence.
Jim Pinkerton
Cougar GT-E Registrar
427XR7
#6
Post by 427XR7 » 17 Jan 2018, 07:50
Original tips are known to have "witness" rub marks on the top where they contact the rear valence. I second Jim's memory on the distances.
jsv
#7
Post by jsv » 22 Jan 2018, 12:57
Mine do have the rub marks, and coupled with Jim's info, I think I can get it right. TY all!
