Covering my car during the winter
What to know about a particular Cougar? This is the place to make the request.
Matt176
#1
Post by Matt176 » 21 Sep 2017, 20:31
Hello everyone
I need some direction with the best way to store my car outside during the fall into spring months. What kind of cover to use and how to keep out the rodents etc.
Thanks
badcatt
Re: Covering my car during the winter
#2
Post by badcatt » 21 Sep 2017, 21:35
What part of the country are you in? This helps with factoring in the type of weather your car will have to endure. Dry mild areas you don't need as much protection as wet, Icy or humid areas. But as you most likely know covered storage is better than out in the open and in door climate controlled storage is best.
Neal Jacobson.
1970 XR-7 White "Ginger"
See ya on the hiways,
they are an entire banquet
- Mark Twain -
Matt176
#3
Post by Matt176 » 21 Sep 2017, 22:35
I'm in Westchester New York. So I get the cold and snowy weather. My car is newly painted and doesn't have any glass installed. So I would like to cover this car as best I can without ruining the paint etc
Thanks
badcatt
#4
Post by badcatt » 22 Sep 2017, 00:28
I'll see if I can find a good source of info for that kind of weather. But do not use a plastic tarp touching or resting on the car. It will trap moisture and cause all kinds of problems. Depending on how much snow you get a 10 X 20 canvas carport like this page has,
https://www.google.com/search?q=10X20+c ... 45&bih=864
Only problem is roof load and wind. I use to have one set up at my last place. I had it lag bolted to 20" 4X4's and used ratchet straps to help hold it in place in case of high winds. I would recommend a more expensive one over a cheep one as the cloth and steel members most likely will be better quality. Costco usually has them.
Neal Jacobson.
- Mark Twain -
BossElim69
Supporting Member
Supporting Member
#5
Post by BossElim69 » 22 Sep 2017, 05:20
I think you would be better off renting a storage unit then trying some method of covering it up outside. The cost of renting a unit for a few months will seem cheap compared to trying to repair damage to a newly painted car.
Brian Carpenter, President CATS classic Cougar club
67 Cougar road course racer
67 Cougar project car
67 Cougar GT
68 XR7-G trailer queen restoration.
68 Restomod
69 Boss 302 Eliminator
69 XR7 390 survivor
69 XR7 428CJ 4spd
70 Boss 302 Mustang
1993 Harley Davidson
2004 F250 diesel
2004 Jeep Overland 4.7L H.O.
78 Ford F 150 Ranger
08 Cobalt SS
Matt176
#6
Post by Matt176 » 22 Sep 2017, 07:40
Thanks badcatt. The carport type is not going to work because of the wind and snow plus I really don't have room for that kind of structure. What would you recommend to keep rodents from making a nest in the car?
93RGTE
#7
Post by 93RGTE » 22 Sep 2017, 08:45
Admittedly this is coming from someone who doesn't face that kind of weather, but why don't you just inspect the car every so often as weather permits?
+1 for renting indoor storage for 3-4 months, especially in its current state - new paint and no windows.
Gary
Sir Ed
#8
Post by Sir Ed » 22 Sep 2017, 09:08
The other issue is the snow load pressing down on the rear and front windshield on the cover. If the glass is missing.
Plus melting water not finding a place to drain. Leaking through the cover. No matter how waterproof it supposedly is.
See if there is a friend that has a garage you could rent for $50 a month?
1967 Standard, 289 4 barrel
Yorgle
Contact:
#9
Post by Yorgle » 22 Sep 2017, 09:21
What about those places that shrink wrap boats? They must do something to deal with moisture.
1968 XR-7 Augusta Green, J-Code, 5 litre, Autolite 6100, 5 spd, convertible with heated seats, cruise control and rear sway bar.
BTW, I think electronic ignition is pointless.
Matt176
#10
Post by Matt176 » 25 Sep 2017, 10:21
Thanks for all the input. It helps to get different view points
