67 or 68 question
What to know about a particular Cougar? This is the place to make the request.
jkbk67
67 or 68 question
#1
Post by jkbk67 » 23 Jul 2017, 12:03
Hey guys, Ive got a question about my late model 67. I've been under the assumption that someone has put a 302 in it along the way as the 67 didn't have the 302 but I've recently (now) had to pull the heads off for bad gaskets and , in running the exhaust manifold numbers , it shows as 67/68 302 heads. Now given that it could have been changed , is there any possibility, in a late 67 (think it was March) that the 302 is Stock? Can't happen these days but stories do abound of "oddities" caused by parts shortages. Thoughts?
1967 S Code
Re: 67 or 68 question
#2
Post by 1967 S Code » 23 Jul 2017, 12:34
The first thing I'd say or ask is, do you have a Marti report for your Cougar? It will tell you exactly how your Cougar was built.
https://www.martiauto.com/martireports.cfm
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
Royce
#3
Post by Royce » 23 Jul 2017, 14:48
Back in the day when you needed a valve job you took your heads to the local machine shop and exchanged them for a fresh rebuilt pair. Lots of our cars ended up with parts that are "close" to correct but not correct as a result.
jkbk67 wrote:
23 Jul 2017, 12:03
XR7-G Registrar
Mach702003
New Member
#4
Post by Mach702003 » 04 Aug 2017, 08:17
On your post you stated you ran the numbers off your exhaust manifolds, The exhaust manifolds off a 289 and 302 are the same, you would need to run numbers on block and heads to know if the true year.
