1973 turn signals
67429merc
1973 turn signals
Post by 67429merc » 07 Mar 2018, 13:13
Im working on a 73. And when the ignition key is in the acc. position the blinkers work! But when the key is in the run position they do not? Ive changed the ignition switch and they work they same? any ideas??
67 standard(my first car) 428 4 speed
68 xr7
69 eliminator
70 eliminator
65 f100
70 mustang convertible
67 vw convertible
CatsRock
Re: 1973 turn signals
Post by CatsRock » 07 Mar 2018, 17:06
Sounds like your loosing power somewhere if they work in accessory position.
See if the below helps your voltage checks :smoke:
http://www.thuntek.net/cougars_unlimited/69seqts.htm
08 Suburban
1973 XR7 351Q Vert
EX 1975 Cougar XR7
EX 1972 Cougar XR7 Vert
EX 1967 Cougar
kuchs72cat
Post by kuchs72cat » 14 Mar 2018, 21:37
check the steering column harness
