Blown engine?
ssava
Supporting Member
Supporting Member
Contact:
Re: Blown engine?
#11
Post by ssava » 04 Mar 2018, 19:18
Thanks.
We found shrapnel inside (under the intake manifold). One of the spark plugs was smooshed down too.
Looking at new engines now. Ugh.
"Esmerelda"
Franklin, TN
badcatt
Re: Blown engine?
#12
Post by badcatt » 04 Mar 2018, 19:59
ssava wrote:
04 Mar 2018, 19:18
Thanks.
On the lifter galley? Wow! Do you have a picture?
Neal Jacobson.
1970 XR-7 White "Ginger"
1970 XR-7 Convertible Blue
1971 XR-7 Bright Blue with Blue "Up Beat" interior
See ya on the hiways,
they are an entire banquet
- Mark Twain -
JETEXAS
Contact:
Re: Blown engine?
#13
Post by JETEXAS » 04 Mar 2018, 20:34
Very sorry for your misfortune, but on the bright side, now you have so many options.
If you have the original block, I'm sure it can be machined. You can choose to overbore it and add a mild cam, and add something like GT40 or Edelbrock Performer heads.
If you don't have the original block, but you want to take the car back to original, WCCC sells rebuildable cores that they'll date match to your car.
If you don't care about originality and want to go the cheap route, there's engine exchange places that sell remanufactured motors fairly cheap, usually with a one year warranty.
You can also order a new crate motor through Jegs, Summit or CJ Pony Parts. They have stroker options where they can get 500hp out of a 302 block.
If you love to deal with wiring, you can score a late model fuel injected 5.0 and drop that in.
Two things to remember:
- If you go with a 70 or newer 302, they have 4-bolt crank pulleys, so you'll either need to change the harmonic balancer to make your 3-bolt crank pulley work or buy a 4-bolt crank pulley with 3-bolt spacing of the Vs.
- If you go with roller heads, the cool Cougar valve covers won't fit.
ssava
Supporting Member
Supporting Member
Contact:
Re: Blown engine?
#14
Post by ssava » 05 Mar 2018, 07:48
badcatt wrote:
04 Mar 2018, 19:59
ssava wrote:
04 Mar 2018, 19:18
Thanks.
Photo Mar 04, 8 10 16 AM.jpg (139.54 KiB) Viewed 215 times
Photo Mar 04, 4 53 40 PM.jpg (68.54 KiB) Viewed 215 times
Photo Mar 04, 4 49 03 PM.jpg (126.51 KiB) Viewed 215 times
Photo Mar 04, 4 49 00 PM.jpg (101.76 KiB) Viewed 215 times
Photo Mar 04, 4 48 52 PM.jpg (117.29 KiB) Viewed 215 times
Photo Mar 04, 3 58 53 PM (1).jpg (106.19 KiB) Viewed 215 times
"Esmerelda"
Franklin, TN
mo2872
Contact:
Re: Blown engine?
#15
Post by mo2872 » 05 Mar 2018, 08:06
Ouch. Do you know if the engine is the original? If not, I'd be looking at new/crate.....but it's not my $$$, so.....:shrug:
T3
Yup, that guy, the hooligan.
ssava
Supporting Member
Supporting Member
Contact:
Re: Blown engine?
#16
Post by ssava » 05 Mar 2018, 08:15
I honestly don't know. But assume it is. How can I tell?
"Esmerelda"
Franklin, TN
JETEXAS
Contact:
Re: Blown engine?
#17
Post by JETEXAS » 05 Mar 2018, 08:34
Oh man, that really stinks. Reminds me of when I lost a valve on the highway in my 66 289. When I pulled the engine apart the valve was actually imbedded into the piston. I still have that piston around somewhere.
The failure was in the worn valve guide and valve stem. However, it was a big backfire under hard acceleration that led to the failure, and I finally traced that down to bad wiring on the back of the ignition switch which would heat up and basically shut off the engine momentarily.
It was the original engine in that car, so I had it rebuilt bored .030. I think it was about $3k all said and done, but that was back around 2001.
zman
Supporting Member
Supporting Member
Re: Blown engine?
#18
Post by zman » 05 Mar 2018, 09:50
mo2872 wrote:
05 Mar 2018, 08:06
Did you end up doing a rebuild or go crate.
69 Cougar 351W 4V, FMX Auto, PS,PDB, AC
55 Ford 2dr Customline 302 4sp
06 Ford F250 SC 4x4
2012 Ford Fusion SEL
97 Arctic Cat Cougar 550 L/C
99 Arctic Cat Jag 440
mo2872
Contact:
Re: Blown engine?
#19
Post by mo2872 » 05 Mar 2018, 09:54
zman wrote:
05 Mar 2018, 09:50
mo2872 wrote:
05 Mar 2018, 08:06
I bought someone else's rebuild, as it was local.....
T3
catlover
Supporting Member
Supporting Member
Re: Blown engine?
#20
Post by catlover » 05 Mar 2018, 10:02
mo2872 wrote:
05 Mar 2018, 08:06
I would say that if the date on block is close to date of heads (4H12) which is Aug.12 1964, then the engine is not original to the car, way to early.
There is never time to do it right, but always time to do it over
67 Cougar restomod
69 Elim. 428 SCJ orange/ white
CCOA 7574
