What is this called? And how hard is it to remove?
ssava
Contact:
#1
Post by ssava » 21 Feb 2018, 16:59
Hey all.
We think a wires off and need to see if we can fix it. We feel two screws near the windshield. But wanted to see if we could get any info from anyone who took one off before.
And what is this called???
"Esmerelda"
Franklin, TN
ssava
Contact:
Re: What is this called? And how hard is it to remove?
#2
Post by ssava » 21 Feb 2018, 17:00
Sorry. Uploaded from my phone and the forum rotated it.
"Esmerelda"
Franklin, TN
xr7g428
Site Admin
Site Admin
Contact:
#3
Post by xr7g428 » 21 Feb 2018, 17:17
Before you take this down, why do you think a wire is loose?
Legendary Cougar Magazine
Currently in the Cat House
ssava
Contact:
#4
Post by ssava » 21 Feb 2018, 17:27
xr7g428 wrote:
21 Feb 2018, 17:17
The park brake light was on all the time. Then my son tapped it a few times (like they do in the movies when the fuel gauge on an airplane is off) and it went off.
He tapped it again. Went on.
Then again... and it's off for good.
"Esmerelda"
Franklin, TN
cougarrand
#5
Post by cougarrand » 21 Feb 2018, 19:57
Remove the screws in the front. Then there a couple of clips that hold it on, they are like the clips on door panels. You carefully pry it loose.
Randy Feuillerat
67 XR7 GT 390 4V
68 390 X code XR7
68 XR7-G 302 2V
70 XR7 Convt 351 2V
70 Eliminator 351 4V 4 speed
Local Hero
#6
Post by Local Hero » 21 Feb 2018, 20:07
I've had mine out a few times for different reasons.
It comes out easy. Getting the screws to line back up with the holes when installing it back is the tricky part.
Don't laugh...But I never have a helper. I held a mini flashlight in my mouth so I could use both hands to hold it up in place, and use an ice pic to realign the holes and then get one of the screws started.
I just call it the overhead console.
Mark
Buckeye Boys Rod & Custom - East
Anyone can restore a classic... it takes a real man to cut one up.
ssava
Contact:
#7
Post by ssava » 21 Feb 2018, 20:12
Great. Thanks!
"Esmerelda"
Franklin, TN
xr7g428
Site Admin
Site Admin
Contact:
#8
Post by xr7g428 » 23 Feb 2018, 14:21
It sounds like you probably have two problems, the lose wire or loose bulb, and the parking brake light switch itself. The parking brake light switch is attached to the parking brake actuating mechanism. It is pretty hard to get to under the dash. The most common problem I have found when the light stays on is that the switch is either bent up or it has rotated away from the little nub that opens the switch to turn off the light.
This thread has some pictures of the switch or at least a similar one. viewtopic.php?f=3&t=8931
1967 S Code
#9
Post by 1967 S Code » 23 Feb 2018, 14:55
It’s called overhead console. I think that is the first safety sticker I’ve ever seen attached to a console. I’d leave it in place if you can. I wonder if that sticker is even reproduced for concourse restorations.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
ssava
Contact:
#10
Post by ssava » 23 Feb 2018, 16:25
Cool. Thank you both.
This is our project for the weekend (hopefully it's not a BIG project)
"Esmerelda"
Franklin, TN
