Engine/Trans fitment help please
tdz16
#1
Post by tdz16 » 14 Feb 2018, 12:57
Hey All, I’m Tom, new to the forum.
I just picked up quite the project in a 1969 Cougar last weekend. The doors had been swapped out but I was told it was originally a 351W/4 Speed Toploader car. It now has a 302.
So, after pulling the motor and trans last night, I started questioning whether the car was an original 4 speed car. When I removed the trans crossmember, it had two metal tabs welded to it in order to move the trans mounting holes approx 3 inches forward (which did line up with the current 4 speed mounting studs. The crossmember is the type with three mounting “ears”, two on the passenger side and one on the driver side. Looking online this appears to be an automatic crossmember.
The trans tag says “RUG E 2” which seems to mean it’s from a 1968 289 car.
The engine has intake manifold markings identifying, at least the manifold, as an early 80’s mustang 5.0. (I didn’t separate engine from trans just yet to see other markings).
I don’t really care if the car was originally a 4 speed or not, I’m going to keep it a 4 speed but I was hoping someone could explain the 3 inch mounting hole spacing difference and if all it will take is the proper crossmember to line up the mounting holes correctly. Also, would the shifter hole require expansion or relocation?
Thanks in advance!
-Tom
1969XR7Vert
Re: Engine/Trans fitment help please
#2
Post by 1969XR7Vert » 14 Feb 2018, 13:35
Hi Tom,
Welcome to the forum.
Yes, sounds like you have a AT X member. The proper X member should get the trans mount to bolt up - as long as the tailshaft on the TL is the right one for the car, should be if the tail is correct for an RUG-E2. A Ford or Hurst Comp Plus shifter should work with the stock tunnel opening, which is the same for an AT or MT.
Regards,
Robert
BossElim69
Supporting Member
Supporting Member
#3
Post by BossElim69 » 14 Feb 2018, 13:42
Sounds like they took the original FMX auto trans cross member and modified it for the 4 spd top loader. I think this is the correct cross member you want. https://secure.cougarpartscatalog.com/c ... attribs=87
RUG-E2 = 1968 Mustang, Cougar 289 wide 28-spline
Brian Carpenter, President CATS classic Cougar club
67 Cougar road course racer
67 Cougar project car
67 Cougar GT
68 XR7-G trailer queen restoration.
68 Restomod
69 Boss 302 Eliminator
69 XR7 390 survivor
69 XR7 428CJ 4spd
70 Boss 302 Mustang
1993 Harley Davidson
2004 F250 diesel
2004 Jeep Overland 4.7L H.O.
78 Ford F 150 Ranger
08 Cobalt SS
69XRRR7
#4
Post by 69XRRR7 » 14 Feb 2018, 20:03
Welcome to the forum. Loads of good info and people here. Hope to see some pics of your car and let us know where you are from.
69 XR7 San Jose built
Always under construction
Slightly improved 351W
CCOA member #9421
tdz16
#5
Post by tdz16 » 15 Feb 2018, 10:06
Thanks for the help guys. It definitely seems like that other x-member would locate the holes correctly for the 4-spd.
So taking into account I’m not looking to necessarily make this car period correct or anything, how does everyone feel about using a t-bird or similar 429 in my car (they’re A LOT cheaper than 428s, lol)? I think I’d have to change out the front end, right? Would it handle horribly with that much weight up front or with the appropriate upgrades would it be ok? Also, would I be able to beef up my 4 speed to handle the 429?
Any tips for fixing the sheet metal lip around the rear window while I’ve got your attention? I see a bead roller and lots of welding in my future, haha.
I’m originally from Long Island, NY. Live in Melbourne, FL now. Thanks for the warm welcome!
-Tom Z.
Leroy R
#6
Post by Leroy R » 15 Feb 2018, 11:01
To go from a small block to a big block you will need the following:
https://secure.cougarpartscatalog.com/f ... attribs=87
https://secure.cougarpartscatalog.com/s ... attribs=87
If you don't already have a 24" radiator you will also want these for a big block.
https://secure.cougarpartscatalog.com/d ... attribs=87
https://secure.cougarpartscatalog.com/3 ... attribs=87
Aside from that I'm not sure what else it takes to convert from a small block to a big block.
9F91H581221
#7
Post by 9F91H581221 » 15 Feb 2018, 11:25
Melbourne. I lived there just outside downtown for a few years. Had 4 Cougars at the time. My daily driver was a 70 XR-7 that had a mild 460. Sometimes I miss driving year round.
1969XR7Vert
#8
Post by 1969XR7Vert » 16 Feb 2018, 11:28
If you want big cubes and don't want the weight in the front (producing a "boat"), consider building a 351 stroker (Windsor or *gasp* Cleveland). But to answer your question, a Lima engine will go into your car. A tight fit but one or two people here have done the swap.
wish
#9
Post by wish » 16 Feb 2018, 17:23
This might be useful for seeing the potential of a 429/460 swap ...
viewtopic.php?f=10&t=8642
Just my $.02
wish
69 Cougar, That 70s Truck, 84 Cherokee Chief 2dr, 88 Grand Wagoneer, 95 Grand Cherokee,96 Mustang
tdz16
#10
Post by tdz16 » 20 Mar 2018, 12:10
Thank you for the resources. There’s a 390 out of a truck available locally that I can pick up relatively cheap, I was wondering what’s involved in making that fit?
FYI- I’ll probably start a thread for the body work soon, which has been my main concentration so far.
Thanks again.
-Tom
