1969 XR7 Roof emblem badge logo
CoogaFan
#1
Post by CoogaFan » 29 Dec 2017, 20:12
I want to repaint the round emblem on the roof pillar and also would like to take the backing off to clean and paint. It's held on by some small rivets? I'd like to know how to reattach it and if I can get a new backing and clips for it. The one on the other side fell off towing it home... :( Any other tips are welcome. I'm planning to use very thin model paint and a hypo-needle to apply.
2017-12-29 17.57.47.jpg (71.37 KiB) Viewed 426 times
2017-12-29 17.57.19.jpg (95.05 KiB) Viewed 426 times
ccarney69
Re: 1969 XR7 Roof emblem badge logo
#2
Post by ccarney69 » 29 Dec 2017, 22:11
I’m fairly sure that the backing plates are not reproduced. If they are I’m sure someone will chime in and correct me.
Keep in mind that after it’s painted it gets a thick clear overlay. You should make sure your paint will survive that process. I do not have any information on the rivets.
I bought a Set from a forum member here who restores them to a very high quality. You must send in good cores with the backing plates in order to purchase a set if I remember correctly.
1968 GT-E 427 Standard Nordic Blue/Black Décor, driver
1969 XR7 R Code 4 Speed Yellow/Black Top Black Interior, current project no.1
1969 XR7 Q Code C6 Green/Black Top Dark Ivy Green Interior, current project no. 2
CCOA #8275
MACC
CoogaFan
#3
Post by CoogaFan » 30 Dec 2017, 12:57
Thanks good to know, last night playing around with it, it kinda came loose and pulled easily off so now I can clean it but not sure the best way to reattach it. Also someone mentioned finger nail polish, so I'm gonna play with that today and I have some thick varnish to try too.
Cougar Bill
Supporting Member
Supporting Member
#4
Post by Cougar Bill » 30 Dec 2017, 19:28
Paint the base with SEM Landau black. The paint can be model paints. Gloss Black, White & "Ruby Red" The over coat was a plastic similar to "Decoupage" excuse my French! Trick was to get the base hot. Then slowly poor the plastic while blowing gently w/ a straw to diminish bubbles.
Or pay someone else!
Try just painting them. Bend clip to regain strength. Re assemble w/ adhesive on the pins only. Wait 24 hrs.
To install - palm the emblem (fingers pointing down) & with a strong downward push - in & down.
They might click. Just be sure they are on the pins & stay!
Enjoy your work!
Back in the day....... the original hub caps centers matched this emblem.
1970 XR-7 428 Ramair 4 speed (now under restoration)
1970 Eliminator Boss 302
1969 XR-7 428 R-code 4 speed
1969 Std. 428 R-code C-6
1969 XR-7 Convertible 351 AOD
1969 XR-7 Convertible 428 C6
1969 XR-7 351 5 speed "RestoMod" New 525Hp "pacemaker"
https://www.youtube.com/watch?v=SBkOzr7N13Y
1968 XR-7 X-code
1968 XR-7 302-4v 4 Speed (J-code)
1967 XR-7 302 & AOD Green- Wife's Cat
www.cougarbill.com
CoogaFan
#5
Post by CoogaFan » 30 Dec 2017, 20:05
Cool! Thanks, yeah the nail polish didn't thin down well so I got some testors enamels, thinner & some triple-thick varnish... I'll try your trick heating the emblem up and blowing on it.
badcatt
#6
Post by badcatt » 30 Dec 2017, 20:49
What ever you use for the over coat make sure is is UV safe. It will degrade otherwise and as it does it will discolor.
Neal Jacobson.
1970 XR-7 White "Ginger"
1970 XR-7 Convertible Blue
1971 XR-7 Bright Blue with Blue "Up Beat" interior
See ya on the hiways,
they are an entire banquet
- Mark Twain -
CoogaFan
#7
Post by CoogaFan » 31 Dec 2017, 14:59
More good tips... after painting it i don't want to put the wrong stuff on. Not having luck finding UV resistant decopage. So any recommendations welcome. Also, how thick should it be on the emblem? I haven't seen a good one and the best pic I have of a new one looks pretty thick above the letters around the rim, but not sure about the inner part. Its not above the cat is it? And lastly, glossy or satin?
69XRRR7
#8
Post by 69XRRR7 » 01 Jan 2018, 18:52
Keep us posted with your progress. Keep sending pictures as you go too.
69 XR7 San Jose built
Always under construction
Slightly improved 351W
CCOA member #9421
CoogaFan
#9
Post by CoogaFan » 01 Jan 2018, 20:32
69XRRR7 wrote:
01 Jan 2018, 18:52
Well i did give it a go today... took a couple pix with my phone but unfortunately the quality and lighting were sub-par.
I'm using the Testors gloss enamel paint. For the black I thinned it down enough to run like ink, only a few drops to the capful i mixed. I put it in a blunted syringe like the ones used to refill ink cartridges and slowly squirted a little here and there along the outside rim. I tilted it back and forth and it filled in all the spaces and cracks and self-leveled itself nicely. It dried nice and glossy and level.
After black.jpg (91.21 KiB) Viewed 302 times
Before the black completely dried, i started with the red. The grooves around the shield I used the same technique and the diamonds I just needed to touch the syringe to them to fill with paint. I made several little mistakes but with various tools managed to scrape cut or wipe them away. You see here after the white was applied the mistakes. But toothpicks exacto knife, pencil eraser, syringe and magnifier helped to fix them.
After White.jpg (136.02 KiB) Viewed 302 times
Here's an original one I assume, So when I'm done painting i'll have to cover the whole thing with about a 1/4" of plastic...
Tomorrow I'll try to work on it more.
scottfzeller
Contact:
#10
Post by scottfzeller » 02 Jan 2018, 07:58
Great progress! Can't wait to see the finished emblem!
Scott Zeller
1969 Cougar XR7
CCOA Member# 9559
ROTM December 2016:https://classiccougarcommunity.com/foru ... =33&t=7055
C.A.T.S. Classic Cougar Club - Club Services Director
http://www.catsccc.com
