Kick down rod end bushings
halbey
Post by halbey » 07 Nov 2017, 17:27
Is there a replacement for the plastic bushings on either end of the kick down rod. One of my bushings is cracking - still usable at this point. My kick down rod is for a 1969 FMX.
superbond
Re: Kick down rod end bushings
Post by superbond » 06 Apr 2018, 09:14
Yes there is. I bought some about 8 months ago off eBay. They worked excellent. Check there. I’ll try to find his contact info. But with eBay after so long it’s hard to bring up your purchases but look there
halbey
Post by halbey » 07 Apr 2018, 00:05
Superbond, thank you for the reply - I thought I needed to rephrase the question. What are they actually called? Any other description would be great.
waterlife
Post by waterlife » 07 Apr 2018, 11:15
the plastic grommets always crack, I bought an assortment, tough to get the one you need first time. Easy to trim/drill out if close enough to stock
1970 COUGAR M CODE
halbey
Post by halbey » 07 Apr 2018, 13:16
I found them on ebay. I will give it a try.
superbond
Post by superbond » 07 Apr 2018, 14:01
Yeah they work ok.
