No power to coil
blaineja
No power to coil
#1
Post by blaineja » 31 May 2017, 18:35
I'm getting no power to my coil. I did run a wire from
Battery direct to the coil and the engine started. I replaced the ignition switch no luck. Not sure if there is a fuse I can check. I'm figuring it's the tach. Is there a easy way to bypass the wiring from tach to wire for now. I do have a good rebuilt tach for replacement but would this solve the problem?
Any help would be appreciated.
Jeff
1969 Yellow XR-7
Midlife
Contact:
Re: No power to coil
#2
Post by Midlife » 01 Jun 2017, 04:15
There's a two wire plug into and out-of the tach. Take the one plug not attached to the tach housing and jumper the leads. The car should start but the tach won't work.
blaineja
#3
Post by blaineja » 01 Jun 2017, 06:49
Thank You. Will give it a try.
1969 Yellow XR-7
blaineja
#4
Post by blaineja » 01 Jun 2017, 06:53
It's. 69. Do I need to take the dash and gauge cluster off to access the plugs?
1969 Yellow XR-7
blaineja
#5
Post by blaineja » 01 Jun 2017, 07:58
Is there any way to easily check to see if the tachometer is the problem before I start taking the dash apart?
1969 Yellow XR-7
xr7g428
Site Admin
Site Admin
Contact:
#6
Post by xr7g428 » 01 Jun 2017, 15:48
Check to see if you are getting power at the coil with the ignition switch in the start (starter cranking) and run positions.
Legendary Cougar Magazine
Currently in the Cat House
waterlife
#7
Post by waterlife » 01 Jun 2017, 20:17
blaineja wrote:
01 Jun 2017, 06:53
Yep, dash pad then cluster PITA!
1970 COUGAR M CODE
xr7g428
Site Admin
Site Admin
Contact:
#8
Post by xr7g428 » 02 Jun 2017, 08:32
Are you getting power to the coil during cranking? If not, the problem is probably not the tach.
