C6 Transmission Identification
XR7--428
Post by XR7--428 »
Is there a way to tell what vehicle a C6 transmission came from without removing it from the car? I know they stamped the VIN on the top and I can't access that. Are there any other markings, date codes, stampings, castings that I can get to to tell? If so where are they?
The transmission tag is not there either. Also is there a way to know what line of vehicles a particular servo came in?
I've seen conflicting info on this, so I'm not sure, but will an R servo work in any C6? Could someone not change the servo itself and just replace the cover with one that has an R on it?
The only thing I can see on the C6 that I'm looking are the following. D servo with FOMOCO and a part number that looks to be A-C6AP-70027-A, a raised circle with a 3, a small O and a diamond with what looks like a Walmart star in it. Other side has some letters and numbers. Looks like FCBAP 7006D.
I'll post some pics.
1969 XR-7 428 Ram Air C-6
Re: C6 Transmission Identification
Post by Royce »
D servo would indicate a low performance application. C6AP sounds like a 1966 or 1967 case. The case was made differently beginning with 1968 model year. The 1968 - later cases have a C8AP casting number.
The case can be machined to accept an R servo but will not accept one without modification by a skilled machinist.
XR7--428 wrote:
22 May 2020, 14:35
XR7--428
Post by XR7--428 »
Is there a way to distinguish a 66 or 7 case from the later ones other than the C8AP? I guess it could be an 8. Sometimes hard to tell between a 6 and an 8.
Can you put an R servo cover over any of the other servos? Swap out a D for an R?
Post by Royce »
It looks like C8AP in your pictures. You may be able to install an R servo. Be aware the R servo required a different apply lever too.
XR7--428 wrote:
22 May 2020, 15:27
XR7--428
Post by XR7--428 »
Royce wrote:
22 May 2020, 19:49
XR7--428 wrote:
22 May 2020, 15:27
What about just a cover with R on it without changing t the actual servo or apply lever? Car shifts just fine the way it is.
XR7--428
Post by XR7--428 »
Done some more research. Apparently the servo covers had the same numbers regardless of what year they were made or which vehicle they were in. In this case C6AP-7D027. Since it's missing the ID tag, the important thing here to ID is what's on the left side. The casting numbers which are RF C8AP-7006-D. This would make it a 68 case being C8. The car is a 69 model, but was built in mid to late 1968. Should it have a C8 or C9 or could have either one to be right?
Bluestuff
Post by Bluestuff »
Just curious,
when was the first application for the C6 trans ?
And what was the “ ridge back “ version on ?
Post by Royce »
The C8 case was used at least through 1970, perhaps longer. There should be a VIN stamped on top of the case at the rear.
XR7--428 wrote:
23 May 2020, 11:20
XR7--428
Post by XR7--428 »
Royce wrote:
23 May 2020, 16:54
Can you see the VIN stamp with the trans in the car?
Post by Royce »
It's possible to see it either with a borescope or using a mirror and taking a flash photo of the mirror. It appears to be the right case for 68 - 70 but the servo never would have come in a Cougar originally.
XR7--428 wrote:
23 May 2020, 18:11
Royce wrote:
23 May 2020, 16:54
