OEM Muffler Dimensions
69XR7RestoMod
Post by 69XR7RestoMod » 25 Feb 2018, 15:18
Does anyone have the exact dimentions of the mufflers for a 69 M Code?
Trying to figure out if a Dynomax Turbo Flow 17748 will fit - they are 4.24 H x 9.75 W x 20” L Body, 25.5” total length.
Currently running 17733 which are 14” or 18.5” total and are a bit too loud.
Being almost 50% longer, I would expect the 17748 to be about right
1969 XR-7 Restomod 408ci 483HP/523TQ, FiTech, TKO-600
J_Speegle
Re: OEM Muffler Dimensions
Post by J_Speegle » 25 Feb 2018, 15:23
Your application would have had a single transverse muffler mounted between the rearend and the gas tank. Not individual ones like on later year Cougars
Would guess your request should be for 70 mufflers
If I'm reading the factor charts correctly
Long 19" (does not include inlet and outlet length) Overall 38"
Tall 4"
Wide 10 1/2"
Inlet 2 1/8"
Outlet 2 1/4"
70b302cat
Supporting Member
Supporting Member
Post by 70b302cat » 25 Feb 2018, 18:02
J_Speegle wrote:
25 Feb 2018, 15:23
Tall 4"
Wide 10 1/2"
Inlet 2 1/8"
Outlet 2 1/4"
Jeff,
I have to disagree with you. The only year that a classic Cougar had a transverse muffler was 1967 according to my MEL mpc. Below is the 1969 351 dual exhaust page, it does show as service replacements in the upper section the 1970 Mustang mufflers (D0ZZ), but the lower section of the page shows the factory original parts (C9WY). The 1970 page uses 1970 Cougar mufflers (D0WY).
69 m exh.jpg (92.85 KiB) Viewed 140 times
Dave
Eliminator Registrar eliminator@cougarclub.org
Mercury Cougar Eliminator Registry
CCOA # 7558
CCNE # 08
70 Convertible 351C 4V Close ratio
70 Cyclone Spoiler 429 SCJ 4 speed Drag Pak
70 Eliminator B302 4V Close ratio
70 Eliminator B302 4V Wide ratio Super Drag Pak Cat
70 Eliminator 428 SCJ 4 speed Drag Pak
85 Capri ASC McClaren 5.0 5 speed
J_Speegle
Post by J_Speegle » 25 Feb 2018, 22:37
Sorry reverted back to Mustang ::) thanks for the correction
69XR7RestoMod
Post by 69XR7RestoMod » 26 Feb 2018, 04:41
Thanks for the info, looks like the muffler I'm planning on will just fit.
