Replace rag joint with u joint on tilt column
Local Hero
Re: Replace rag joint with u joint on tilt column
#11
Post by Local Hero » 12 Feb 2018, 11:57
xr7g428 wrote:
12 Feb 2018, 11:52
In a straight shot there shouldn't be a problem. Only if you are having to make a bend. The reason that I mentioned it is that a hot rod that I have been helping with required a pretty goofy looking extension to reach around the exhaust and to the steering rack and we had to add an additional u joint to make it work right. Before we fixed it it had a weird feel, as you turned the wheel the effort changed a bunch. It almost felt like it was binding up in spots. I learn new things every day.
Yeah, I've seen set ups in Street Rods that had to route around a bunch of things in order to hit a R&P. I've seen as many as three joints in one run. So yes, there could be binding issues if not done correctly.
Mark
Buckeye Boys Rod & Custom - East
Anyone can restore a classic... it takes a real man to cut one up.
69XR7RestoMod
#12
Post by 69XR7RestoMod » 12 Feb 2018, 12:03
Thanks Mark! That Toyota box looks very similar to the Borgeson. Glad to hear no vibration comes through. Did you find the steering to be noticeably tighter when you swapped for the ujoint?
1969 XR-7 Restomod 408ci 483HP/523TQ, FiTech, TKO-600
Local Hero
#13
Post by Local Hero » 12 Feb 2018, 13:17
Yes it was tighter especially since my rag joint was actually off the Toyota to fit that box, and I modified it. My skills have come a long way since then.
Mark
69XR7RestoMod
#14
Post by 69XR7RestoMod » 12 Feb 2018, 14:44
So all I need now is to find out the dimensions of the lower shaft and I can try to find one with the correct end for a ujoint. I'd rather not pull my column to find out.
Anyone here have a 68/69 tilt column taken apart?
fordnutz
Contact:
#15
Post by fordnutz » 12 Feb 2018, 16:01
I’m sure you can get the dimensions from the Borgeson website. Here’s the part number of the rag joint for their 68 up Ford kit. 990016
Thanks, Scott Ferguson
President, Fordnutz Cougar Club
E-mail President@Fordnutz.org
Visit the Fordnutz Cougar Club on the web http://www.fordnutz.org
Past Chairman, Cascade Cougar Club
http://www.CascadeCougarClub.com
Past Chairman, Cougar Club of America
http://www.cougarclub.org
CougarCJ
#16
Post by CougarCJ » 12 Feb 2018, 16:07
You can interchange the lower shafts between tilt and fixed columns. I believe that 1968-70, and then 1971-73 all have the same tube shape and size.
Changing lower shafts is an inexpensive way to get around the tilt only rag joints.
Fixed column lower shafts are plentiful.
Scott Behncke 1968 XR7
Carcheologist - West Coast Classic Cougar
69XR7RestoMod
#17
Post by 69XR7RestoMod » 12 Feb 2018, 16:41
Scott,
Thank you! That's the info I needed. Now I can order up parts and do the swap without having the car down for long.
fordnutz
Contact:
#18
Post by fordnutz » 12 Feb 2018, 16:57
No problem, glad to help. Good luck with it.
