Lug nut size
drewk86
Lug nut size
#1
Post by drewk86 » 26 Jan 2018, 14:44
I'm needing to order some new lug nuts for my 68 to go with its Torq Thrust D rims . What size lugs do I need? 1/2?
Thanks
Royce
Re: Lug nut size
#2
Post by Royce » 26 Jan 2018, 14:49
1/2" - 20 NF RH
XR7-G Registrar
Midlife
Contact:
Re: Lug nut size
#3
Post by Midlife » 26 Jan 2018, 18:51
Royce wrote:
26 Jan 2018, 14:49
1/2" - 20 NF RH
That should be UNF not NF.
Royce
Re: Lug nut size
#4
Post by Royce » 28 Jan 2018, 12:40
You are correct only because there is no difference between the two threads. So while you can use a 1/2" - 20 UNF tap to thread a lug nut, it didn't get made that way. The use of 1/2" - 20 NF threads on Ford product lug nuts predates the ANSI/ASME change to UNF designations. So a tap and die set like the Snap On one in my garage has some dies and taps marked NF because there was no need to change tooling. 1/@" -20 NF is one that is still marked NF because that's what it is. I bought this tap and die set in the late 1970's so I don't know what Blue Point sells today. Maybe they are marking them UNF now.
Midlife wrote:
26 Jan 2018, 18:51
Royce wrote:
26 Jan 2018, 14:49
1/2" - 20 NF RH
half inch - 20 NF Blue Point Die.jpg (98.44 KiB) Viewed 291 times
XR7-G Registrar
