Front End Rebuild Kit
stevie thompson
#1
Post by stevie thompson » 20 Jan 2018, 18:46
Will a 1969 or 1970 Mustang Front End Suspension kit fit the 1970 Mercury Cougar
1967 S Code
Re: Front End Rebuild Kit
#2
Post by 1967 S Code » 20 Jan 2018, 18:50
It should.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
stevie thompson
#3
Post by stevie thompson » 20 Jan 2018, 19:02
Thanks
[CCCGallery][/CCCGallery]
69XR7RestoMod
#4
Post by 69XR7RestoMod » 20 Jan 2018, 19:10
Mustang and cougar are the same for the same year car. 69 and 70 have different spindles, tie rods, drag link......
1969 XR-7 Restomod 408ci 483HP/523TQ, FiTech, TKO-600
stevie thompson
#5
Post by stevie thompson » 20 Jan 2018, 19:26
Thanks great info i am looking at upper control arms and lower control arms and tie rod ends i have did research and i thought they were interchangeable the spindles are in great shape new front and rear brakes and slotted rotors and calipers and drums
catlover
Supporting Member
Supporting Member
#6
Post by catlover » 21 Jan 2018, 09:38
If you have a 69, stay with what fits 69 .
There is never time to do it right, but always time to do it over
67 Cougar restomod
69 Elim. 428 SCJ orange/ white
CCOA 7574
69XR7RestoMod
#7
Post by 69XR7RestoMod » 21 Jan 2018, 11:05
i think he said he had a 70. So he should stick with that, 70 is a bit stronger
Cougar Bill
Supporting Member
Supporting Member
#8
Post by Cougar Bill » 22 Jan 2018, 11:03
Try here. Best brand is Moog. You can rebuild the upper arm w/ shaft kit #8131
http://www.rockauto.com/en/catalog/merc ... suspension
1970 XR-7 428 Ramair 4 speed (now under restoration)
1970 Eliminator Boss 302
1969 XR-7 428 R-code 4 speed
1969 Std. 428 R-code C-6
1969 XR-7 Convertible 351 AOD
1969 XR-7 Convertible 428 C6
1969 XR-7 351 5 speed "RestoMod" New 525Hp "pacemaker"
https://www.youtube.com/watch?v=SBkOzr7N13Y
1968 XR-7 302-4v 4 Speed (J-code)
1967 XR-7 302 & AOD Green- Wife's Cat
www.cougarbill.com
fastmerc
#9
Post by fastmerc » 22 Jan 2018, 20:11
Keep in mind that tie rod ends changed from 69 to 70!
A-arms and strut rod parts will remain the same.
Steve
Caring for Cougars since 1978. Picking classic parts from junkyards well before that!!
stevie thompson
#10
Post by stevie thompson » 23 Jan 2018, 16:45
Thanks[CCCGallery][/CCCGallery]
