Originality check -- 1969 painted pinch weld?
SPLINEHEAD
Re: Originality check -- 1969 painted pinch weld?
#11
Post by SPLINEHEAD » 14 Jan 2018, 07:35
BossElim69 wrote:
13 Jan 2018, 19:13
Sgeegle has it documented
viewtopic.php?f=4&t=8638&p=87468#p87468
Thanks Brian, Everyone. I do recall seeing that document and when I get to my laptop I will probably find that I downloaded same. Forgot all about it.
Gary Hill
Pole Cat
1969 XR7 390 S code 4bbl C6 3.0 TrueTrac rear end
1969eliminator
Contact:
#12
Post by 1969eliminator » 14 Jan 2018, 09:31
Here's the info I used from the other forum when we did my car ...
by "snakepit"
"Yes the cars had this done before the front fenders were done from the front edge to the rear valance area. The application also produced overspray of black over the exterior color overspray and the epoxy primer mix on the undecarriage. The rear wheel wells may have been blacked out at the same time by the same worker.
Remember that the edge of the black out should not show a masking tape line as they were likely done free hand originally. Many owner use a technique called back-masking to tape off the area. It does not produce a sharp edge if done correctly"
I can't say this is correct but that's what was available to me at the time.
1969 Eliminator 351-4V M-code (original owner)
Harry
website: https://harrya.webs.com
propayne
Contact:
#13
Post by propayne » 14 Jan 2018, 10:44
Here are some photos I have grabbed off of past threads on this subject (need to do mine).
- Phillip
J_Speegle
#14
Post by J_Speegle » 14 Jan 2018, 15:29
DeadStang wrote:
13 Jan 2018, 23:51
What rattle can paint would be best to use? This car isn't mine, but I do have a couple of others that need this little detail completed as this is one of the things -- like body color fender bolts -- that bugs me.
Remember or at least consider that this is not just the pinchwelds but the floor (less the shadow produced by the pinchweld) and any part of the body that hung down from the floor got direct application of black and or overspray that could reach inward often to 1/2- 3/4 of the way to the driveline tunnel. Amount of paint and distance was a result of the angle of the spray when applied. Not unusual to find heavy runs on some cars in some close (to the rocker and spray) surfaces.
Examples of things that hung down would be front frame rails, convertible front seat supports, rear spring torque boxes and so on.
Adding this detail or correcting this with a rattle can will nor produce the amount of black that would have been produced at the factory and doing it after the car is assembled means that allot of parts that should not have black may get black on them. But you can at least black out the edge that is most visible when people see the car pass by. Once you know this detail your eyes will almost be automatically drawn to it every time you look at a classic Cougar - Just what happens
DeadStang
#15
Post by DeadStang » 14 Jan 2018, 19:19
J_Speegle wrote:
14 Jan 2018, 15:29
Yep -- just like the painted front fender bolts.
Before I knew about this (I attended a super interesting lecture by Bob Perkins using a low-mile B9 as an example at an IMMM in Montana a few years back), I remember seeing this detail on half a dozen crusty old cars over the years and thinking some previous owners were sloppy losers who had rattled the rockers and done a really bad job. :lol:
Mike_B_SVT
#16
Post by Mike_B_SVT » 15 Jan 2018, 12:36
propayne wrote:
14 Jan 2018, 10:44
- Phillip
One of my pet peeves, and like others mentioned, it draws the eye. Once you see it you can't unsee it!
Aaaand I need to do mine too (among about a zillion other things, LOL!) >.<
Mike B.
CCOA # 9553
Cat Bites Man!
Blitz
#17
Post by Blitz » 15 Jan 2018, 15:13
Yeah it's one of those details that can make a significant difference in making the lines of the car look crisp. Interesting to see the pictures of spray-on black there... a few months ago when Dave W. stopped by with his two original paint 1970 Eliminators, we looked at the blacked out pinch welds areas, and the black was clearly brushed on, rather than sprayed on. Maybe a change for 1970?
-Andrew Chenovick
RIDES:
-1991 Mazda Miata: fun driver
-1986 Volvo 240: dependable beater / "Goldilocks"
J_Speegle
#18
Post by J_Speegle » 15 Jan 2018, 17:17
Blitz wrote:
15 Jan 2018, 15:13
.................... Interesting to see the pictures of spray-on black there... a few months ago when Dave W. stopped by with his two original paint 1970 Eliminators, we looked at the blacked out pinch welds areas, and the black was clearly brushed on, rather than sprayed on. Maybe a change for 1970?
Current understanding is that the brushed on black out was when a car was mistakenly missed and an inspector caught it later down the line. Too much hassle pulling a car off the line and moving it back to a booth. Its believed that were were a few gallon cans (or coffee cans) with a brush and paint made available on the line at some point. We see the same practice every so often (when and where spray painting would be the norm) on other areas of the exterior was were blacked out You have the interior of the front fenders on some years of Cougars, back engine compartment edge of fenders on Cougars in other years, headlight buckets on 69-70 Mustangs and so on.
The brush on pinch welds are pretty rare but seen back as far as 66-67 on Dearborn cars as well as other plants
We still don't know for sure if the pinch weld black out was applied by hand (worker with a spray gun) or with the use of mounted spray jets (like the floor panels from the firewall rearward) operated by a switch that was triggered on and off by the moving unibody. Think the evidence favors the stationary jets
