Originality check -- 1969 painted pinch weld?
DeadStang
#1
Post by DeadStang » 13 Jan 2018, 00:01
Should the pinch weld that sticks down, running along the side length of the car wheel-to-wheel, to the inside of the rockers (actualy where the rockers meet up with the floorpans) be painted black for a 1969 Cougar -- like it is on the Mustang? Or is this car just missing the trim so I am seeing the weld that I usually don't see?
GLC
Re: Originality check -- 1969 painted pinch weld?
#2
Post by GLC » 13 Jan 2018, 07:34
Yes it should have the black pinch welds.
jcbingcougar
#3
Post by jcbingcougar » 13 Jan 2018, 08:43
Both. The car is missing its rocker moldings and the pinch weld should be painted black.
Jeff Bingaman
1970 Cougar
1956 Ford F100
1960 Dodge Phoenix
2017 Mustang GT Premium
2017 F150 Platinum
http://www.cascadecougarclub.com
SPLINEHEAD
#4
Post by SPLINEHEAD » 13 Jan 2018, 10:44
I was unaware of the black pinch weld. So did they paint the black and just, how do I say, let the color over spray onto the bottom of the rocker and the maybe onto the flange of the pinch welds? In other words how does the transition look? I think I would like to do this on mine as I have never liked the looks of the white flange sticking down.
Gary Hill
Pole Cat
1969 XR7 390 S code 4bbl C6 3.0 TrueTrac rear end
catlover
Supporting Member
Supporting Member
#5
Post by catlover » 13 Jan 2018, 11:03
Get a can of semi gloss black and spray pinch-weld and keep as much as you can off of the bottom of rockers and floor pan.
There is never time to do it right, but always time to do it over
67 Cougar restomod
69 Elim. 428 SCJ orange/ white
CCOA 7574
ccarney69
#6
Post by ccarney69 » 13 Jan 2018, 13:56
Are same pinch welds behind the rear wheels body color?
1968 GT-E 427 Standard Nordic Blue/Black Décor, driver
1969 XR7 R Code 4 Speed Yellow/Black Top Black Interior, current project no.1
1969 XR7 Q Code C6 Green/Black Top Dark Ivy Green Interior, current project no. 2
CCOA #8275
MACC
BossElim69
Supporting Member
Supporting Member
#7
Post by BossElim69 » 13 Jan 2018, 19:13
Sgeegle has it documented
viewtopic.php?f=4&t=8638&p=87468#p87468
Brian Carpenter, President CATS classic Cougar club
67 Cougar road course racer
67 Cougar project car
67 Cougar GT
68 XR7-G trailer queen restoration.
68 Restomod
69 Boss 302 Eliminator
69 XR7 390 survivor
69 XR7 428CJ 4spd
70 Boss 302 Mustang
1993 Harley Davidson
2004 F250 diesel
2004 Jeep Overland 4.7L H.O.
78 Ford F 150 Ranger
08 Cobalt SS
jcbingcougar
#8
Post by jcbingcougar » 13 Jan 2018, 21:54
ccarney69 wrote:
13 Jan 2018, 13:56
No. They are also blacked out.
Jeff Bingaman
1970 Cougar
1956 Ford F100
1960 Dodge Phoenix
2017 F150 Platinum
DeadStang
#9
Post by DeadStang » 13 Jan 2018, 23:51
jcbingcougar wrote:
13 Jan 2018, 21:54
ccarney69 wrote:
13 Jan 2018, 13:56
What rattle can paint would be best to use? This car isn't mine, but I do have a couple of others that need this little detail completed as this is one of the things -- like body color fender bolts -- that bugs me.
jcbingcougar
#10
Post by jcbingcougar » 13 Jan 2018, 23:57
Any semi-flat black like Krylon 1613 would work just fine. You could also use DP90LF or some other catalyzed semi-flat too.
Jeff Bingaman
1970 Cougar
1956 Ford F100
1960 Dodge Phoenix
2017 F150 Platinum
