Driveshaft Length 8” to 9” Rearend Swap
Chopaka
#1
Post by Chopaka » 16 Dec 2017, 15:09
What is the correct driveshaft length for a 1967 390 4 speed Cougar.The car had an 8” rearend I swapped for the correct 9”,the driveshaft is now to long to bolt in.I will get it shortened but would like to know the correct length.Any help would be greatly appreciated.Thanks
Cougar Bill
Supporting Member
Supporting Member
Re: Driveshaft Length 8” to 9” Rearend Swap
#2
Post by Cougar Bill » 17 Dec 2017, 11:09
You should be able to get the correct length by measuring from the end of the trans to the center line of the rear u-joint cap / center of the rear yolk. I just had one made for a customers 69 351W. Got a new yolk, 2 u-joints (Spicer) & the drive shaft was made & balanced w/ new tube steel. All for under $200
1970 XR-7 428 Ramair 4 speed (now under restoration)
1970 Eliminator Boss 302
1969 XR-7 428 R-code 4 speed
1969 Std. 428 R-code C-6
1969 XR-7 Convertible 351 AOD
1969 XR-7 Convertible 428 C6
1969 XR-7 351 5 speed "RestoMod" New 525Hp "pacemaker"
https://www.youtube.com/watch?v=SBkOzr7N13Y
1968 XR-7 X-code
1968 XR-7 302-4v 4 Speed (J-code)
1967 XR-7 302 & AOD Green- Wife's Cat
www.cougarbill.com
Trixie
#3
Post by Trixie » 17 Dec 2017, 12:23
Correct length is 53 1/32" Measured from the center line to center line of the u-joint mounting. (on the shaft)
I would double check this by measuring before doing any shortening. This measurement is for the shaft only
It does not include the yolk or any other attaching parts.
This is only my advice, I will not be held responsible for any errors.
Dave & SuAnn Harty
1969 351W-4V XR-7 Convertible
Proudly Owned Since 1980
CCOA Member #9129
MACC Member
IMOA Member #7330
Our Cougars, Past & Present-
1969 XR7 2DR Convertible 351W-4V, 1968 XR7 2DRHardtop 302-4V, 1969 2DR Standard 351W-2V, 1969 XR7 2DR Hardtop 428-4V Cobra Jet Ram Air, 1970 XR7 2DR Hardtop 351W-2V
Believe who you wish to believe & what you choose to believe. I can only offer my advice.
allenman85
#4
Post by allenman85 » 17 Dec 2017, 19:58
What's with all the eggs underneath your cars?
Cougar Bill wrote:
17 Dec 2017, 11:09
Got a new yolk
Trixie wrote:
17 Dec 2017, 12:23
I suspect they mean yoke (not yolk) -- and if you use the same dimension yoke you do not have to change lengths. However there are 3 to 4 length yokes that can be mated with a 9". Correct driveshaft length should only be determined after install.
1970 Cougar. 351C/FMX/AC/PS/PB/Comp Green w/White Top, 3:00 open
Now: 622 HP, 351W w/AFR, solid roller, 418ci, C6, 3.50:1 posi, 3" Magnaflow SS exhaust
Chopaka
#5
Post by Chopaka » 18 Dec 2017, 00:35
Thanks for the info.It appears I will need to get a new driveshaft as the one I have now is 2 3/4” inch dia. and has smaller u-joints than what the 9” is set up for.I have a local shop that will be able to fabricate a new one.The old one will be for sale if anyone needs it.
